I have two projects which have all their MXF files in the same default Media Composer directory (AvidMediaFiles/MXF/1). I would like to pull the Media files out of that default directory for one project and place those files onto an external drive to use with my Notebook which also has Media Composer running on it. I understand about moving project files over onto another system, but how do you take the media files along? I can't take the whole directory of about 750GB with me. The two projects roughly split that space. Is there a way to extract media files I need? Also, in the future, is there a way to save MXF Media Files into separate subdirectories for each project? I know that Ctrl-5 will bring up the option of directing the media files into a specific drive, but I didn't see anyway of directing them into specific directories.
As silly as it might sound, I would take out the disk (taking that is SD project) and hook it to a USB case.
This would be the fastest option instead of using MDV to copy the files to another disk.
The best option is to have it on e-SATA but this depends on if your laptop futures an e-sata connection.
Desktop
Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Asus 3060 12GB|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
Laptop
MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)|W11 Pro
NLE
DR Studio 18.5|MC 2023.3
3 Heads Digital Films
Hi
I'm working on the trail version of MC 4.05 so I'm newbie of MC. For what I have see you have to options to separete media files for every project. They can be appllied at the benginning of the project . You can using one of these two way
1- create a virtual hard drive (uisng windows commands)
2- rename the MXF folder to an other one and rename back as "MXF" when you want re-open the project (obvoiuslly before you must change the name folder previous folder)
At the point you are the only solution I saw is to use MDV (make search on this forum fo MDV)
Ugo
Andrew Fomin:I understand about moving project files over onto another system, but how do you take the media files along?
You can consolidate the media to an external hard drive. I would:
1. Open the project you want to move.
2. Open the Media Tool.
3. Select all drives and the current project.
The Media Tool should now show you all the media from the current project.
4. Select all.
5. Consolidate the media to an external hard drive.
Now you can take the project folder and external hard drive to another system.
ciao,Carl
