Latest post Tue, May 1 2012 11:22 AM by George Angeludis. 283 replies.
Page 1 of 19 (284 items) 1 2 3 4 5 Next > ... Last »
  • Fri, Mar 12 2010 6:33 PM
    Essential Tips
    Desktop
    Corsair RM750X/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.4/Corsair 32G DDR3/PNY Quadro P2000D(385.08)/Samsung 850 Pro SSD(OS) 256 GB/ 2x2TB WD RE4@RAID 0/LG BH16NS40/W10 Pro 64bit/Media Composer Software 8.9.3 with Symphony • PhraseFind • ScriptSync Option/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    3 Heads Digital MediaVienna Frames
  • Fri, Mar 12 2010 7:04 PM In reply to
    Re: Essential Tips
    Desktop
    Filed under: ,
  • Fri, Mar 12 2010 7:39 PM In reply to
    Re: Essential Tips
    It's important to note that 3D Warp (in the blend group) is the master template you want to start with to build your own customized effect from scratch, whether 2D or 3D. It's also important to remember that it IS a template, it is not a pre-built "canned" effect as many other choices are. So just dropping a 3D warp icon on a clip does not alter anything in the picture until you start working with the adjustments. And, as George points out, it is a very powerful base to start from.
  • Fri, Mar 12 2010 11:31 PM In reply to
    • Mike Shaw
    • Kent, United Kingdom
    • Posts 1,424
    • Points 19,730
    Re: Essential Tips
    Well, in that respect it's like the editors in Liquid. Which is good: I never ever use a 'preset' effect - except maybe a dissolve transition  (don't think I've ever looked at the presets even, in Liquid).  Always build an effect from scratch - so I will feel at home with these (though I am finding the keyframing a bit different to handle for some reason).
    My problems so far lie elsewhere ... but that's another topic, another thread.
    MC6.0.3.2 Gigabyte GA-X58A-UD3R Rev2 MB, Intel i7-950 3.06Ghz, 12GB DDR3 1333Mhz RAM, 1x500GB, 3x1TB HDrives, 2+1TB Network drives, nVidia Quadro FX1800... [view my complete system specs]
  • Fri, Mar 12 2010 11:41 PM In reply to
    Re: Essential Tips
    Mike:
    If you design a lot of your own transitional effects, here's a good one. Create a bin and name it "Quick Transitions". Now, any transitional effect you save to that bin will be available in the drop down menu in the quick transition (dissolve) tool - activated by the backslash key just above enter on the QWERTY side.
  • Fri, Mar 12 2010 11:45 PM In reply to
    Re: Essential Tips
    Desktop
  • Fri, Mar 12 2010 11:47 PM In reply to
    Re: Essential Tips
    Desktop
  • Fri, Mar 12 2010 11:53 PM In reply to
    Re: Essential Tips
    Thank you very much, George. I appreciate that. Smile
    {EDIT} And yes, the quick transitions bin is for real. Just make sure you name it EXACTLY - Quick Transitions.
  • Sat, Mar 13 2010 12:13 AM In reply to
    Re: Essential Tips
    All right, here's another one that's not too widely known - editing title clips. Most people edit titles in the timeline, and while you can modify it and store it as a new title clip, the existing title in the timeline will get modified whether you want it to or not.
    Solution: CTRL double click the title clip in it's bin. The title tool opens with that title clip ready for editing and re-saving. Never have to touch a timeline. Saves a lot of keystrokes and clicking.
  • Sat, Mar 13 2010 12:32 AM In reply to
    Re: Essential Tips
    Desktop
  • Sat, Mar 13 2010 12:49 AM In reply to
    Re: Essential Tips
    Desktop
  • Sat, Mar 13 2010 7:15 PM In reply to
    Re: Essential Tips
    Desktop
  • Sun, Mar 14 2010 4:05 AM In reply to
    Re: Essential Tips
    To insert a new audio or video track into a multi-layer stack at the position of your choosing:
    For video, CTRL + ALT + y and make your choice in the next window
    For audio, it's CTRL + ALT + u, and same as above
  • Sun, Mar 14 2010 4:10 AM In reply to
    Re: Essential Tips
    To create a customized name for a track indicator instead of V1, A1 and so on, right click on the desired indicator and choose "rename track".
  • Sun, Mar 14 2010 4:16 AM In reply to
    Re: Essential Tips
    Here's a very good tutorial on using the motion tracker parameters in the effects side of Avid.
