Latest post Thu, Mar 11 2010 3:46 AM by Andrew Fomin. 0 replies.
Page 1 of 1 (1 items)
  • Thu, Mar 11 2010 3:46 AM
    • Andrew Fomin
    • Joined on Mon, Oct 19 2009
    • Seattle, Washington USA
    • Posts 7
    • Points 110
    AVCHD and MC
        This procedure applies to Windows PCs using MC 4.05.
    I used Main Concept's AVCHD to P2 transcoder to create the
    translated files and card directory structure.  The program is free
    and may be downloaded from the Panasonic website. You will have to
    provide an email address for them to send you the download link.
         In MC, if there is no Import P2 option under the Files pull-
    down menu, make sure that AMA Volume Management is turned off under
    Settings\AMA\Volume Mounting.
        I am assuming that you have created a bin for the files
    already.  It is a two stage import procedure.  First, Go to Import
    P2 in the Files pull-down menu and select Clips to Bin.  Navigate
    to the Contents directory of the virtual card and highlite the
    "Contents" directory title and hit OK.  The clips will appear in
    the bin and can be viewed in the source window. If you place the
    bin view to "text" and expand the window enough to see the drive
    column, you will notice that the drive is designated as "Virtual".
    This means that your media location will disappear as soon as you
    exit MC. If you go back into MC, you will find that the media will
    be "OFF LINE" and you cannot Relink.  So once you have moved the
    clips to bin, do not exit MC, otherwise you will have to start
    over.
         In the second stage, you will first select (highlite) all the
    clips in the bin.  Next, go to Import P2 again, but select "media"
    this time.  Your clips will be imported for real. This may take a
    few minutes - depends on the number of clips.
    Desktop: Home assembled Mid-tower with MSI P45 Neo F motherboard, Q6600 Quad Core Intel CPU, 8GB RAM, Nvidia Gforce 9400GT video card, Audigy SE sound... [view my complete system specs]
