Latest post Thu, Sep 1 2016 11:38 PM by AndrewAction. 20 replies.
  • Fri, Jan 15 2010 9:16 PM
    • MarcRose
    • Joined on Wed, Nov 19 2008
    • Rochester, NY
    • Posts 21
    • Points 320
    Import/Export Crashes MC Everytime
    We run 3 identical MC 3.1.3 systems tied to Unity. For months one of the systems crashes out of MC immeadiatly when the Import or Export command is used. Never even gets to the point of selecting what to import or what type of file to export - crashes as soon as Import or Export is selected - no error message, MC just vanishes back to the XP desktop.
    With 2 other systems available for file I/O we've just worked around it. All 3 systems are identical in hardware and software versions. We've reinstalled MC few times on the problem system and it operates normally in all other respects. I've been working on Avids for the better part of 15 years and can usually track down problems but this one...!
    My guess is something in XP is shutting it down but I don't know what. I've checked the XP Event Viewer for odd happenings but see nothing out of the ordinary.
    MC 3.1.3, HP XW8400, 2TB Unity, [view my complete system specs]
    Filed under: , ,
  • Sat, Jan 16 2010 4:18 AM In reply to
    • wkumingo
    • Chicago
    • Posts 172
    • Points 2,380
    Re: Import/Export Crashes MC Everytime
    If you haven't tried already: Create a new user profile?  Check QuickTime version?  Also open QuickTime Player and check QuickTime Preferences --> Advanced --> set Video to use Safe Mode (GDI only), not DirectX.
    Once, I had an odd problem (but don't remember what exactly) that was seemingly unrelated to QuickTime, but it was cured by the Safe Mode setting.
    Self-built -- Always current MC version with AJA KONA 1 card OS: Windows 10 Pro 64-bit, System: X99 Motherboard, Core i7-6850K, GTX 1080 Ti, 32GB RAM... [view my complete system specs]
  • Mon, Jan 18 2010 3:38 PM In reply to
    • MarcRose
    • Rochester, NY
    • Posts 21
    • Points 320
    Using QT ver 7.4.5 preference is set to use Safe Mode.
    Have tried other user profiles that import/export on our other 2 systems with no problem
    Any other ideas?
  • Mon, Jan 18 2010 3:46 PM In reply to
    • Posts 10,282
    • Points 219,150
    Marc....
    MC 3.1.3 should be running QT 7.5.5 as per the version matrix.
    http://avid.force.com/pkb/LegacySearch?DocId=267087&Hilite=version+matrix
    Also, you are on XP so I assume you have SP2 or SP3 installed?  Right?  Also, you have WMP 11 installed too right?
    The QT might seem insignificant but that might be it.
  • Mon, Jan 18 2010 4:13 PM In reply to
    • MarcRose
    • Rochester, NY
    • Posts 21
    • Points 320
    We have 2 other MC's running with QT 7.4.5. Both Import/Export without issue.
    SP2 installed.
    WMP 11 installed
  • Mon, Jan 18 2010 4:46 PM In reply to
    • MarcRose
    • Rochester, NY
    • Posts 21
    • Points 320
    Just in case updated QT to 7.5.5. MC stiil quits as soon as Import is selected.
  • Mon, Jan 18 2010 4:54 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Mark,
    Quit out of the Unity Client and see if you can import to your Internal HD.
    Does that work?
  • Mon, Jan 18 2010 4:55 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Also, I don't see your version of Unity and the Unity Client. Can you tell us what they are?
  • Mon, Jan 18 2010 6:14 PM In reply to
    • MarcRose
    • Rochester, NY
    • Posts 21
    • Points 320
    I unmounted/logged off the Unity workspaces and tried an import. MC did not quit - a login window opened asking for my password to the Unity workspaces. I put in the password and then MC quit. Next time I did the same thing and it quit without asking for a password.
  • Mon, Jan 18 2010 6:16 PM In reply to
    • MarcRose
    • Rochester, NY
    • Posts 21
    • Points 320
    BLKDOG:
    Not sure of the Unity version. For Avid Unity Media Network the Admin tool is ver 4.0 450
  • Mon, Jan 18 2010 6:18 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Ok, still need the version of Unity and the Unity client tho...
    So what is happening is there is a problem with the connection to your storage. We need to check that the ATTO card (Assuming you are fibre connected)'s firmware and Driver versions are right, that the Fibre cable is good and anything else in that storage path we can think of. Something is up in that path to your Unity.
  • Mon, Jan 18 2010 6:19 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Ok so your Unity is v4.0.4. I just need to know your Unity CLIENT version on the MCs themselves.
  • Mon, Jan 18 2010 6:23 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    One problem I see is that, with MC 3.1.3, you need to be running Unity v4.1.6 - 5.1.2. This could be at the heart of the problem. You need to upgrade your Unity to run those client versions.
  • Mon, Jan 18 2010 6:24 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
  • Mon, Jan 18 2010 6:41 PM In reply to
    • MarcRose
    • Rochester, NY
    • Posts 21
    • Points 320
    BLKDOG:
    Thanks for your help.
    Where would I find the Unity client version info?
    Also, I have 2 other MC systems connected to the same Unity running the same hardware and software. Those systems import/export with no problem. The problem sytem digitizes and plays media to/from Unity without issue - It's only file import/export that is a problem.
