Latest post Thu, Jun 16 2011 5:22 PM by EndOfTape. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Jan 12 2010 1:14 PM
    • LDani
    • Joined on Tue, Jan 10 2006
    • Hungary, Budapest
    • Posts 47
    • Points 580
    Ingest from XDCAM using Transfer Manager
    Hi
    I would like to ingest XDCAM (sd dv25) discs into Avid Unity v5 shared storage with Interplay Transfer Manager. (we haven't got interplay Sad )
    My Transfer Manager configuration is the following:
    FTP parameters: Profile Name: xdcamdev Server name: 192.168.5.71 Username: admin Password: pdw-1500 Server Type: SONY_XDCAM_PROFILE Playback format: DV 25 Default Dir: nothing Ftp mode: active Ftp Port: 21
    Ingest transfer enabled
    Max sim. ing. transfers: 1
    Ingest devices: xdcamdev
    Dir. for incoming transfers: U:\Avid Meiafiles\MXF\Avid13.1  (it is an FC attached unity volume)
    Total transfers: 6
    When I try to start an ingest task form the client using FtpClipList I got the following error:
    "ANF::Client::open: Can't connect to xdcamdev"
    I can reach xdcamdev device using FTP feature of TotalCommander from the client and from the transfer manager too.
    What is wrong? Please help me!
    CURRENT SYSTEM: 4x Avid Media Composer v4.0.5 NitrisDX on HP z400 1x Avid Media Composer v4.0.5 NitrisDX on HP xw8600 1x Avid Symphony v5.0 NitrisDX... [view my complete system specs]
    Filed under: ,
  • Fri, Jun 18 2010 12:25 PM In reply to
    Re: Ingest from XDCAM using Transfer Manager
    Havfe you ever managed to get this to work.
    I'm having exactly the same issue.
    Jeroen van Eekeres
    www.mediaoffline.com
  • Mon, Jun 21 2010 11:27 PM In reply to
    • LDani
    • Hungary, Budapest
    • Posts 47
    • Points 580
    New Transfer Manager version solved the problem. Drag&drop from FtpClipList into Media Composer bin still not working, but if you click on the Initialize Transfer button, it's okay!
  • Tue, Jun 22 2010 6:33 AM In reply to
    Thx for that answer.
    I have some questions.
    - Which version of Transfer manager are you using?
    - Is it a standalone version?
    Jeroen van Eekeres
  • Sun, Jul 11 2010 10:33 PM In reply to
    • LDani
    • Hungary, Budapest
    • Posts 47
    • Points 580
    Unfortunately I can't tell you an excact version of the Transfer Manager. We use it in an Interplay environment (so not standalone). In this case I don't know any possibility to check the TM version. The Interplay version is 2.1.
  • Thu, Jul 22 2010 6:43 PM In reply to
    • EndOfTape
    • Joined on Thu, Jul 22 2010
    • Posts 33
    • Points 395
    Have you looked at this product. It fully supports Interplay and file based ingest for XDCAM.
    http://www.autoingest.com
  • Mon, Jul 26 2010 10:25 AM In reply to
    Very interesting! Thx for thatYes
    Jeroen van Eekeres
  • Thu, Jun 16 2011 5:09 PM In reply to
    • Vitor
    • Joined on Thu, Jun 16 2011
    • Portugal
    • Posts 3
    • Points 15
  • Thu, Jun 16 2011 5:22 PM In reply to
    • EndOfTape
    • Posts 33
    • Points 395
    If you are looking for a fast XDCAM workflow without depending on TransferManager try the free download at
    http://www.autoingest.com/Direct
    Other Avid workflow enhancements:
    http://www.nltek.com/
