I was going to import some P2 files I generated from AVCHD using the Panasonic transcoder. I noticed, however, that there is no Import P2 selection on my File menu. I am using Media Composer 4.02. Do I need to install a P2 driver?
Andy
To view the P2 import function, you need to disable the AMA in the settings panel. After this, close and reopen the MC.
Fernando Alfonsin
www.alfonsindigitallab.com
Thanks. I figured it out, finally. Not exactly well documented unless you know AMA.
