Latest post Mon, Dec 7 2009 11:02 PM by WYTCAT. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Dec 7 2009 3:45 PM
    • WYTCAT
    • Joined on Mon, Dec 7 2009
    • Germany
    • Posts 16
    • Points 230
    Downgrade MC 4 back to 3.5 - no DNA Hardware
    My MojoSDI on MacPro with OSX 10.5.7 doesn't see the DNA-Hardware (Mojo) any more after Downgrade from MC 4.0.4. So does my Adrenaline Box (tried with two different qualified Dongles). Version 4.0.4 works perfectly on both Systems. Did AVID do something with the Installer to prevent Users from Downgrading ? Need to downgrade the Mojo System because the Dongle will stay on Version 3.5 for some more weeks.
    ISIS 5000 • 2x MC 8.7.0, DNxIO, iMac Retina 5K 27" 4.0 Ghz i7 Quad core Late 2015, 32GB, MX395X, OS X 10.11.6 •MC 8.7.0, NitrisDX, MacPro • MC 8.7... [view my complete system specs]
  • Mon, Dec 7 2009 4:43 PM In reply to
    Re: Downgrade MC 4 back to 3.5 - no DNA Hardware
    Shouldn't be an issue...while I haven't downgraded, I have a dual boot system with 3.5.x and 4.0.x and can bounce back and forth with our Adrenaline BOB.
    I'd uniinstall 3.5 and re-install, just in case something screwed up during the process.
  • Mon, Dec 7 2009 4:47 PM In reply to
    • Posts 10,268
    • Points 218,980
    WYTCAT....
    You shoulodnt be having these issues as the DNA devices should be seen by the 4.0.4 upgrade and the 3.5 downgrade.  We did just come out with a back rev utlity but that is for the DX boxes which have different components and design that the Mojo and Adrenaline.
    I suggest you call in to support and have a tech walk you through to see what might be happening.
  • Mon, Dec 7 2009 4:55 PM In reply to
    • WYTCAT
    • Germany
    • Posts 16
    • Points 230
    Thanks for your quick answer Kevin. I wish I had a dual boot System (I used to have earlier when Apple demanded newer quicktime versions for FinalCut/ DVD Studio). Just to waste more time I probably must make myself a fresh HD with just MC 3.5.x. Of course I deinstalled all the old MC files using the corresponding deinstallers. Maybe AVID messed with the (de-)installers so they don't remove all of the old dust. But unfortunately I am not able to track down the issue...
  • Mon, Dec 7 2009 5:16 PM In reply to
    WYTCAT, I suggest a manual uninstall if you want to ensure everything is cleaned up.
    See this KB Article for a list of files and folders to remove.
    Greg
  • Mon, Dec 7 2009 10:52 PM In reply to
    • WYTCAT
    • Germany
    • Posts 16
    • Points 230
    Thank you Fendstrad, I will try to remove everything manually.
    But (@AVID) why am I not able to see or open the linked article with Safari/Firefox on Mac ?
    I like Apple AND AVID so why do you do that to me ?
  • Mon, Dec 7 2009 11:02 PM In reply to
    • WYTCAT
    • Germany
    • Posts 16
    • Points 230
    @Marianna
    Thank you, I know that I should not have these problems because I was used to intelligent AVID (De-)Installers which were able to detect my hardware. I am irritated because I tried on two different machines with two different dongles causing the same trouble on both units...
    I am constantly trying with the help of our reliable support (through AVID support contracts) but no solution so far...
    The easiest way is and will be updating my MOJO Dongle up to MC4 what we actually did but I am curious if the AVID Installer forced me to stay with MC4 and no way back.
