Latest post Tue, Nov 17 2009 8:10 PM by Job ter Burg. 4 replies.
  • Tue, Nov 17 2009 7:38 PM
    Timewarp effects on 50fps footage.
    Hello
    I will soon be working on a UK 25fps production that would like to shoot a lot of slomotion at 50fps or more using RED,  with the ability to use these shots in the film as 'real time' shots as well - speeding up the footage by 200% to make it run at normal speed.
    Is this possible? and will it look ok?
    I am currently working on a project that has some 100fps footage shot on Phantom and we have had success at speeding it up to look the correct speed.
    I have heard that Final Cut Pro performs this task very well with RED footage, but I would be grateful for some clarification on this and appreciate advice or tips from anyone who has tried this with Avid Media Composer.
    Many thanks
    NLYNCH
  • Tue, Nov 17 2009 7:44 PM In reply to
    Re: Timewarp effects on 50fps footage.
    How will you be going from R3D to Avid? MetaFuze will allow you to set the destination format to 1080/25p, AFAIK. That will give you frame-by-frame slowmotion (like with overcranked 35mm). If you need to make them run normal speed, you may apply a 200% motion effect. Should work fabulously. Easiest would be to use a Both Fields 200% effect. This will maintain the resolution of each frame (and keep the result progressive), but it will skip every other frame.
    Symphony Classic Nitris 4.0.4 on 2xQC 2.33 XW8400/8GB Vista Biz 64bit | MC 4.0.5 on 2xQC 3.0 XW8600/8GB Vista Biz 64bit | Mojo SDI | MC 4.0.5 on 2xDC 2... [view my complete system specs]
    You should have no problems.  You just have to figure out the math.
    Hopefully, they shoot at multiples of 25, so the math is easy.  :)
    Media Composer v4.0.5.1; Nitris DX (2x3 GHz Quad-Core Xeon); Adrenaline (2x3 GHz Dual-Core Xeon); Unity LanShare EX 4.1.6 [view my complete system specs]
  • Tue, Nov 17 2009 7:57 PM In reply to
    Thank-you very much.
    We plan to use Meta fuze.
    Thats great information - it's good to be reassured!
    Cheers
    N
  • Tue, Nov 17 2009 8:10 PM In reply to
    Kevin Klimek:
    Not even that. In the traditional Motion Effect, you can set the amount of playback fps. So 60 for 60, etc. Then promote to TimeWarp, if desired.
