Been through one of these and it took forever.
Now looking as 3 cam shoot with multiple segments to deliver.
Is there any P2 like scheme that could be utilized here?
Or should I simply use something like MPEG Streamclip and have production make
DNxHD QTs for me for at least fast-import?
This will go out for grading and broadcast. Starting with Canon H264 QTs, does it make
any sense to transcode to DNxHD 220x? If not which res. should I choose.
Thanks for any help.
MC 3.5.4 8 core MacPro 10gb ram
I recently tried batch converting some Canon footage on a Mac Pro to DNxHD prior to importing to MC but had what I think were gamma issues with rather crushed blacks (It wasn't a 601/RGB issue). Haven't had a chance to investigate fully yet. The files did fast import however, so would probably be fine for offline, but not online. I ended up doing a straight import. Took about 5 times running time but was worth it in the end.
regards
Brian
Thanks for the reply.
Do you take a quality hit with "fast import"? (Re: your offline/online ref) I assumed it was fast as it was in a friendly codec
Those clips I've transcoded to DNxHD with MPEG streamclip look great after I get them in.
I always feel like my clients and production co.s are assuming I'll be using FCP and seem dismayed when
I refer to these laborius ingest times. They may have the right to be, but I think with Canon you still
need to transcode to ProRes for FCP.
What if they (production) use a hardware encoder like Matrox and make DVCProHD clips for me? They get a faster transcode on their end and I can still do fast import?
Hi there, i am not sure if i understood your problem the right way.
i simply just import the 5D /H264 footage to a 1920x1080 MC project with 30fps.
While importing the media is transcoded to mxf/dn x hd 120, 145 or if you like 220.
Maybe thats the wrong way but it seems to work. BUT it takes some time.
ingo
since 17.10.2009 MAC: MC 4.0.0 / Mojo DX / MacPro 2x 2,66 Nehalem / 12 GB Ram / OSX 10.5.8 / QT 7.6.2 / NVIDIA GeFOrce GT 120
WIN: MC 3.5.4 / Mojo analog / Intel 2x 2,8 Xeon / 4 GB Ram / XP SP2 / QT 7.6 / Nvidia Quadro4 580 XGL @ 9.1.3.6
