Latest post Tue, Nov 10 2009 3:41 AM by carlgmi. 8 replies.
Page 1 of 1 (9 items)
  • Sat, Nov 7 2009 6:09 PM
    • lahatte
    • Posts 12
    • Points 100
    Make DVD video for 16x9 and 4x3?
    I'm trying to find the correct settings in order to make a m2v file from Squeeze such that it will appear correctly on a 16x9 television, and be in letterbox on a 4:3 television.  I don't want letterbox or pillars on the 16x9 display.
    I have made a DVD using Encore.  My DVD player is set for a 4:3 letterbox.  On a 4:3 television, the 16x9 menu displays properly (letterboxed), but the video is squished side to side and will not letterbox, no matter what I try.
    Can someone help with this issue?
    Thanks.
    Clay
  • Sat, Nov 7 2009 6:31 PM In reply to
    Re: Make DVD video for 16x9 and 4x3?
    The only way I have had success with is to make seperate 4:3 and 16:9 versions in Avid.
    In the authoring program create a VMG menu as first menu and 2 VTS menus. One of the VTS menus is set to 4:3 and the other to 16:9.
    The end result then depends on a combination of setups in your DVD player AND your monitor.
    Thanks for the continued dongle support
  • Sat, Nov 7 2009 8:24 PM In reply to
    The official way:
    Make only one movie, make it in Squezze at 16:9.
    Normaly, a DVD player should be setted to the ratio from the TV attached at. So, on a 4:3 TV, if the DVD player is corretly setted to 4:3, your 16:9 movie will appear letterboxed by your player.
    The safe way: AndrewActions way Smile
    HTH
    pixel
    XW8200 / Adrenaline DNA /4 GB RAM / MCA 3.0.5, Adobe CS3 [view my complete system specs]
    What is editing? It´s the process of transforming a collection of badly focussed or horribly framed shots containing reversed screen directions, flare and dirt into a smooth visual statement of the script... ... for which the director takes the credit!
  • Sat, Nov 7 2009 11:26 PM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Posts 261
    • Points 2,950
    pixels.paradise:
    That relies on the disc having the 16:9 flag on it though. Otherwise the dvd player would letterbox 4:3 discs also.
    I'm not familiar with any pc authoring apps but in dvdsp you set the disc (or individual titles on the disc) to be 16:9 and then choose whether it should be letterbox or pan-scan on a 4:3 tv.
    2x MC 2.6.6 with Mojo on HP xw8400 MC Adrenaline 2.6.6 on HP xw8400 MC 2.8 on MacPro dual 2.66 Editshare 4.1 [view my complete system specs]
  • Mon, Nov 9 2009 4:20 AM In reply to
    • lahatte
    • Posts 12
    • Points 100
    Well, I've recently created a new m2v file via Squeeze, with the 16x9 DVD preset, and "Maintain Aspect Ratio" selected.  The resulting DVD displays the menu properly, but the video is still squished on my 4x3 TV.
    I hope someone can provide some further insight?
    Thanks.
  • Mon, Nov 9 2009 4:45 AM In reply to
    • Air Traffic
    • Joined on Sat, May 9 2009
    • St. Louis
    • Posts 3
    • Points 45
    I have been battling this same question just this week.  I shot SD 16x9, edited and exported via QT movie with the 16x9 preset. I then imported into Encore and no matter what setting I used, the DVD menu was letterboxed but the movie was squashed 4x3.  I finally exported the movie with the hdv preset and imported the m2T file into Encore.  Encore recognized the 16x9 and displayed properly.  It took a long time to transcode, but the final product is nice.  I was tempted to reinstall quicktime because this is not an efficient workflow.
    Dell 435MT Corei7 6GB TriChannel, Nvidia Quadro FX1700 Dell Core 2 Duo laptop. 3GB , GeForce [view my complete system specs]
  • Mon, Nov 9 2009 10:22 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 4,233
    • Points 48,650
    Air Traffic:
    Could you not tell Encore to interpret your footage as 16x9?  From memory, a right click on the asset should have give you an Interpret As... choice.
    MC 4.0.3 - Asus P6T Deluxe V2 mobo - Intel i7 920 2.66GHz - nVidia Quadro 1700 - 12 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro firewire... [view my complete system specs]
  • Tue, Nov 10 2009 1:48 AM In reply to
    • MikePoglitsch
    • Naperville, IL
    • Posts 113
    • Points 1,515
    Follow Andrew Actions advice, author both a 4x3 and 16x9, give the option to the viewer which one to watch in the menu.
    PC MCA on an 8200, 4GB Ram, MCA 2.8 [view my complete system specs]
  • Tue, Nov 10 2009 3:41 AM In reply to
    • carlgmi
    • Western Australia
    • Posts 367
    • Points 4,510
    jwrl:
    The trick here is to do this before transcoding otherwise this option is not available.
    MC4 with Dongle, 2xQC Xeon, Tyan 5400XT, Quadro FX3500, Adaptec RAID 0-4x1TB, 8G RAM, Creative Audigy, Vista 64 SP1, Matrox Triplehead Digital. Protools... [view my complete system specs]
    Vote 1 - Dongles.
