Latest post Mon, Nov 16 2009 12:43 PM by Larry Rubin. 7 replies.
  • Fri, Nov 6 2009 1:20 AM
    • Mhawkes
    • Joined on Thu, Oct 29 2009
    • Posts 1
    • Points 15
    Help! Problems with Capturing Video from Sony HDV Camera
    Hello!
    I am a newbie at editing and capturing using Avid Media Composer. I borrowed a camera from work, the Sony HVR-HD1000U, although Avid doesn't have an exact configuration for the camera, we use the Sony DCR-PC120 setting at work and it captures fine. I tried using this setting at my own computer at home and it isn't reading it and always says No deck. I am using a firewire to connect it to my HP computer. Any feedback? Help...please?
  • Fri, Nov 6 2009 1:49 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,992
    • Points 107,015
      Moderator: Meridien
    Re: Help! Problems with Capturing Video from Sony HDV Camera
    Hello, and welcome to the Forum! Please take a few moments to fill out your system specifications. Click on your name, then "edit my profile" and then "profile options" to get to the appropriate text field. We need this information to help you.
    In the meantime since you can't find the exact model in the Sony templates, can you confirm that you've tried configuring a channel with "Firwire on OHCI" linked to an appropriate generic dv template?
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Fri, Nov 6 2009 1:24 PM In reply to
    • clmt
    • Joined on Fri, Nov 6 2009
    • Posts 2
    • Points 50
    I have the same problem! But i think this is not an AVID problem, but windows.
    I'm using Sony HVR-Z7 Camcorder on VIA OHCI-konformer 1394-Hostcontrolle.
    AV/C Subunit driver doesn't work, i see it  as "?" in hardware manager :( And I have no idea how to install it.
    msdv.inf and msdv.PNF are on the right place in c:\windos\inf folder. but it dosen't workSuper Angry
    sorry for my english, i do my best! Hmm
    * XP Pro SP 3 * Composer v3.1.2 * Quicktime v7.6.4 * mainboard: MSI K9Ndiamond 2GB RAM 2 Drives: st3250620as (Seagate Barrakuda 250GB... [view my complete system specs]
  • Fri, Nov 6 2009 2:12 PM In reply to
    • jveekeres
    • Athens Greece
    • Posts 671
    • Points 8,470
    Please mention in your system description the type of HP computer and in this case what kind of firewire card you use.
    7x HP XW8400 9x HP XW8200 4x HP XW8000 5x Media Composer 3.1 2x Media Composer 3.1 Adrenaline 2x Media Composer 2.7 Adrenaline HD 1x Media Composer... [view my complete system specs]
    Jeroen van Eekeres
    Ena productions
    Software activation AND dongle is better then only software activation.
  • Fri, Nov 6 2009 3:15 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 3,094
    • Points 35,350
    clmt:
    Your prob is most likely that you are using a VIA chip for your firewire connection, buy a Texas Instrument one instead.
    Some other comments to your profile would be that you are using an uncorrect version of QT for the version of MC that is inside your profile.
    MC 4,03 ( Liquid 7,2 ) V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 8 GB, PNY Quadro 1800, Soundblaster X-Fi... [view my complete system specs]
    Tomas
  • Mon, Nov 16 2009 7:07 AM In reply to
    • clmt
    • Posts 2
    • Points 50
    thx mjolnarn. you seems to be right.
    hmm... i always download the latest version from QT site.
    which one could be the right one? and where can i get it? Confused
  • Mon, Nov 16 2009 7:25 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,094
    • Points 35,350
    You´re welcome, nice to be able to help.
    About versions of Quicktime, doing a search in the knowledge base for version matrix gave me this
    edited ...  and that document is also linked from the first thread on this forum of course ...
    just noticed ..Embarrassed
    Tomas
  • Mon, Nov 16 2009 12:43 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,992
    • Points 107,015
      Moderator: Meridien
    Clmt:
    Be advised that the latest QT version is not necessarily the correct one for you. As per the version matrix, you should be running QT 7.5.5 not QT 7.6.4. You can get earlier versions of QT here.
