Latest post Sat, Nov 14 2009 3:28 AM by jwrl. 4 replies.
  • Thu, Nov 5 2009 6:19 PM
    • Pheral
    • Savannah, GA USA
    • Posts 200
    • Points 2,530
    Trim Mode
    I've finally upgraded my old Xpress Pro system to MC 4 and am learning the ins and outs but have run into an infuriating function that I'm sure is related to a setting I'm missing - whenever I hit the "A" or "S" keys to go to previous or next edits, the system enters trim mode.  Is there a way to turn this off?
    Thaniks in advance.
    System #1 (work): HP XW8000, Dual 3.06 Xeon, 2 Gigs memory, Quadro FX 1100, Standard Mojo, XP Pro SP2, Sony UVW-1800, Sorenson Squeeze 4.5, Cinemacraft... [view my complete system specs]
  • Thu, Nov 5 2009 6:24 PM In reply to
    Re: Trim Mode
    Remap those keys with FF and RW.
    Thanks for the continued dongle support
  • Thu, Nov 5 2009 6:35 PM In reply to
    • Pheral
    • Savannah, GA USA
    • Posts 200
    • Points 2,530
    Re: Trim Mode
    Worked like a charm!  Thank you!
    P.
  • Fri, Nov 13 2009 6:54 PM In reply to
    • JohnnyReboot
    • Southern CA
    • Posts 709
    • Points 8,595
    Re: Trim Mode
    Another solution would be hold the Ctrl key down and click in the clip on the timeline toward the side closest to the edit that you want your cursor to snap to.  Hope that's clear.
    Regards, JR
    Media Composer v3.1.1-IE7-HP xw8000-TYAN Mobo S2663-Dual 2.8 Xeons-Hyperthreading On-3G RAM-Executed Install3GB.bat-Page File Initial/Max set to 2048/4092MB... [view my complete system specs]
    That's right...an xw8000.
  • Sat, Nov 14 2009 3:28 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 4,234
    • Points 48,665
    Re: Trim Mode
    There used to be a keyboard settings file for people migrating from Xpress Pro to MC.  I'm at home at the moment, so I can't look for it, but I'd be surprised if it wasn't still included.  It gives you the full original mappings of the Xpro keyboard in MC.
    MC 4.0.3 - Asus P6T Deluxe V2 mobo - Intel i7 920 2.66GHz - nVidia Quadro 1700 - 12 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro firewire... [view my complete system specs]
