Latest post Thu, Nov 5 2009 8:26 PM by Kevin Klimek. 3 replies.
  • Thu, Nov 5 2009 1:31 PM
    Problem re-opening projects
    CPU Platform: Apple Macintosh MacPro 2 x 2.66GHz GHz Dual-Core Intel Xeon
    Operating System: OSX 10.4.11
    Avid Media Composer: Version: v2.7.2
    Adrenaline HD
    I recently suffered a major CPU failure and had to reinstall the Operating System and Composer software from scratch. Before doing so, I copied the Avid Projects and User folders to an external hard-drive, but now, can't seem to open any of my projects. I open the Media Composer, hit the browse button, locate the Avid Projects folder and choose the project I want to open...but it does not appear in the 'Select a Project' window. Any advice would be most welcome!
    I don't know if it would make any difference, but having reinstalled all the software, the only thing that is different from my previous set-up is that, shortly after I bought the system in January 2008, I upgraded the Media Composer software from 2.7.4 to 2.8 - which was a free download at the time for all 2.7.4 purchasers. This free upgrade does not exist any longer and if I wish to upgrade now, then it has to be to Version 4.
    CPU Platform: Apple Macintosh MacPro 2 x 2.66GHz GHz Dual-Core Intel Xeon Operating System: OSX 10.4.11 Avid Media Composer: Version: v2.7.2 Adrenaline... [view my complete system specs]
  • Thu, Nov 5 2009 6:00 PM In reply to
    • Posts 1,595
    • Points 19,895
      Avid Employee
      Moderator: Broadcast Newsroom
    Re: Problem re-opening projects
    Since media, projects and bins is so critifcal - this is the time I would call support.  You dont want to make a mistake here and having a tech walk you thorugh is the best bet.
    Customer Advocate/Customer Success [view my complete system specs]
    813-493-6800 mobile
    AOL IM avidmarianna
  • Thu, Nov 5 2009 6:32 PM In reply to
    Rodney Butcher:
    Have you tried double clicking on the Project rather than just selecting it when you find it? (If I correctly understood the problem correctlly this works for me with the PC.)
    Thanks for the continued dongle support
  • Thu, Nov 5 2009 8:26 PM In reply to
    Usually, your Avid projects would be here: /Users/Shared/AvidMediaComposer/Shared Avid Projects.
    But, if you're not sure, go ahead and create a new, dummy project.  Then, search for it's name in the finder, and figure out what folder it is in.  Copy your other projects to that location and you should be OK.
    MacPro MCA (v4.0.3/3.5.9/v3.1.4) on 2x3 GHz Quad Core Xeon; Mac Meridien (v12.1.2); Unity LanShare EX (v4.1.6) [view my complete system specs]
