Latest post Thu, Nov 5 2009 1:52 PM by BLKDOG. 3 replies.
  • Thu, Nov 5 2009 1:28 PM
    • dharia
    • Joined on Fri, Sep 19 2008
    • Posts 112
    • Points 1,345
    MC 3.5 to Unity 4.1.6 speed issues
    Hello
    I have a Unity Media Network, running Unity 4.1.6. My AVID Mac Pro's all run Media Composer 3.5 and 4.0.
    The thing is for some reason on all my systems everything has a delay to it. If I open a bin its such a slow process, but then once the bin is open and I'm in the sequence everything is fast and fine. But for example, if I click out of avid and on the OSX desktop and then click back to AVID, it takes a extra 5 sec to refresh everything. Even switching between projects is slow. But if I layback HD to HDCAM or D5, or do anything, the process is fast and without a hitch. But I'd prefer to be able to hit record in my capture tool without having to wait 10sec for the AVID to respond.
    Again I don't think its the computer, its a Mac Pro Quad Core 2.66 XEON. 6gb of Ram.
    The Fibre Cables aren't crimped at all.
    These are a couple things I think are the issue but either way what do you guys see as a easy fix to make things zippy.
    - The Unity 4.1.6 and the Fibre Manager 5.1.3 are so far apart in versions that there is some issue causing the delay. I can't go below Unity 5.0 on the client cause Leopard won't run it.
    - The fact that all my 10k ROM hard drives  are sitting in Chassis that all run at 2 gigabit, as well as my unity machine that runs at 2 gigabit, and the switch that runs at 2 gigabit. Should I upgrade everything to 4 gigabit or will that not solve my issue.
    I did try one thing, I have about 33 workspaces that I mount (total Unity size is 8TB with 6 more TB on the way).  If I only mount 1 workspace and the Projects drive then everything is just as fast as working off the local hard drive, but its when I mount 10-15 workspaces that everything gets sluggish, and with 33 all mounted its very sluggish.
    I work in a promo house, so I need everything available all the time, hence why I need 33 workspaces always mounted.
    I can't afford a Unity 5, its too pricey for me. My Unity machine by the way is a SR2200
    Thanks any input would help!
  • Thu, Nov 5 2009 1:33 PM In reply to
    • dharia
    • Posts 112
    • Points 1,345
    Re: MC 3.5 to Unity 4.1.6 speed issues
    by the way, I use MC 3.5.9 and MC 4.0.3 systems. But I even had this speed issue when my AVID's were MC 3.0 and 2.8 way back.
  • Thu, Nov 5 2009 1:38 PM In reply to
    • dharia
    • Posts 112
    • Points 1,345
    Also I used to have Meridiens only , and with the Meridien AVID's, on G4's, the opening and closing of bins/projects was super super fast on this same exact unity, so I'd like to get that back with these Mac Pro Ntris DX MC 3.5 4.0 based systems.
  • Thu, Nov 5 2009 1:52 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,836
    • Points 201,230
    With MC 3.5.x, I believe you need to be running v5.1.2 of the Unity client. However, I'm going to move this to the Unity forums for the geniuses there to take a look.
