Latest post Sat, Nov 14 2009 3:09 AM by jwrl. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Nov 5 2009 10:17 AM
    • butterfly
    • Hungary
    • Posts 101
    • Points 1,525
    Relinking
    I decided to work from an external disk with all my back-ups after a crash of an internal HDD. AMC opened the project without problem and relinked automatically to the Media Files. This lead to some new observations. I mean new to me. Forgive me if what I say here seems from a dummy.
    My project is a HDV project, but every single clip, before I bring it to the timeline, is transcoded into TR 120. I suppose that all transcoded files are stored in AvidMediaFiles and that the original 1080i footage is no longer linked to or even needed. Am I right? Could I even delete the original HDV/1080i clips?
    MC 3.5.1 software only, Windows XP Pro (SP3), P5Q Mbo, 4 Gb RAM, Quad Core CPU, nVidia Quadro FX580 [view my complete system specs]
  • Sat, Nov 7 2009 2:56 PM In reply to
    • butterfly
    • Hungary
    • Posts 101
    • Points 1,525
    Re: Relinking
    I would be happy with a short answer. For you its not much trouble. Anyway, its not that stupid to ask this, because the way Avid stores its transcoded-consolidated-computed files is not very transparant.
  • Sat, Nov 7 2009 3:16 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 3,094
    • Points 35,350
    Re: Relinking
    Yes, you can delete your old origin captured media once it is transcoded to DNxHD, it is always able to restore it from tape using batch-digitize if you need to in the future
    MC 4,03 ( Liquid 7,2 ) V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 8 GB, PNY Quadro 1800, Soundblaster X-Fi... [view my complete system specs]
    Tomas
  • Sat, Nov 7 2009 4:56 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,991
    • Points 107,000
      Moderator: Meridien
    Re: Relinking
    mjolnarn:
    And you can verify that this is true by using File>Reveal file on both the original clip and the transcoded clip - reveal file will show two completely different coded media files.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Sat, Nov 7 2009 5:29 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,094
    • Points 35,350
    Re: Relinking
    Larry Rubin:
    mjolnarn:
    I also prefer to have the sequense option to show clip properties activated, just to be sure of that I haven´t forgotten something
    Tomas
  • Sun, Nov 8 2009 8:35 AM In reply to
    • butterfly
    • Hungary
    • Posts 101
    • Points 1,525
    Re: Relinking
    I was doing File>Reveal and I bumped on some questions.
    In MediaCreation the Importsettings are set to TR 120. In AvidMediaFiles these imported files appear as MXF files. When I directly (without transcoding manually first) drag one to the timeline, it appears there as a HDV clip. What is the use of the MediaCreation Import settings if it doesn't effect the footage (it remains HDV). Or does it?
  • Sun, Nov 8 2009 11:54 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,991
    • Points 107,000
      Moderator: Meridien
    Re: Relinking
    HDV is a format that is not native to the Avid environment, so the resolution on import will be HDV regardless of the resolution choice in media creation settings. Most users have found that immediately transcoding the imported files to a DnX resolution makes the entire editing process go much smoother than staying in HDV.
  • Thu, Nov 12 2009 8:03 AM In reply to
    • butterfly
    • Hungary
    • Posts 101
    • Points 1,525
    Re: Relinking
    After import I need to make subclips from the HDV clips first before I transcode those subclips to DnX. I need to do that because they are full with corrupted parts, especialy at the end of the clips. I guess it is because I was capturing with HDVSplit. They are M2t files.
    But you are absolutely right. In the beginning I worked with the HDV clips in the timeline and that gave me lot of trouble. With the transcoded clips It goes much smoother.
    Why is HDV not native to the Avid environment?
  • Thu, Nov 12 2009 11:21 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 4,233
    • Points 48,650
    Re: Relinking
    butterfly:
    Sony designed the codec, not Avid.  In that sense it is therefore not a native Avid codec.  However HDV is handled natively by Avid in that you don't have to transcode it to use it.
    Sony designed the codec from the point of view of minimising storage space and not from the point of view of ease of editing.  For that reason any NLE that I've used handles HDV media better if you transcode it to a native format, ie., ProRes for FCP or DNxHD for Avid.  So I repeat: you don't have to transcode it, but it helps.
    MC 4.0.3 - Asus P6T Deluxe V2 mobo - Intel i7 920 2.66GHz - nVidia Quadro 1700 - 12 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro firewire... [view my complete system specs]
  • Fri, Nov 13 2009 3:36 PM In reply to
    • butterfly
    • Hungary
    • Posts 101
    • Points 1,525
    Re: Relinking
    Ok, thanks for the info.
  • Sat, Nov 14 2009 3:09 AM In reply to
    • jwrl
    • Posts 4,233
    • Points 48,650
    Re: Relinking
    You're welcome.
