Latest post Fri, Nov 6 2009 11:54 AM by Baklap. 4 replies.
  • Thu, Nov 5 2009 9:58 AM
    • engalaa
    • Joined on Tue, Sep 25 2007
    • Posts 28
    • Points 390
    Media Network Upgrade
    Dear friends :
    I have Media Network 5 with one Avid Media Composer( Nitris DX)  station and I have also One station ( After effect on PC ) and the other one is After Effect on MAC
    so can I connect all of it with the media network , alsoI 'm thinking to buy another station jsut contain MC 4 without the hardware .
    is it will work ??
  • Thu, Nov 5 2009 1:45 PM In reply to
    • jveekeres
    • Athens Greece
    • Posts 669
    • Points 8,460
    Re: Media Network Upgrade
    If you can connect is only dependant on the number of licenses you have on the dongle of your unity.
    7x HP XW8400 9x HP XW8200 4x HP XW8000 5x Media Composer 3.1 2x Media Composer 3.1 Adrenaline 2x Media Composer 2.7 Adrenaline HD 1x Media Composer... [view my complete system specs]
    Jeroen van Eekeres
    Ena productions
    Software activation AND dongle is better then only software activation.
  • Thu, Nov 5 2009 3:28 PM In reply to
    • engalaa
    • Posts 28
    • Points 390
    I have 8 licenses  so I think it will be okay
  • Fri, Nov 6 2009 8:58 AM In reply to
    • jveekeres
    • Athens Greece
    • Posts 669
    • Points 8,460
    Yes you are.
    Just a piece of advice. I would create a seperate (or more then 1) workspace for the Adobe programs and call them for example "import" and "export" so you have a clear workflow from and to avid and After effects. This will keep avid media and other media seperate. the adobe programs only have acces to these "import export" workspaces. The avids you give acces to all workspaces.
    Good luck.
    Jeroen van Eekeres
    Ena productions
  • Fri, Nov 6 2009 11:54 AM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,825
    • Points 80,630
    engalaa:
    Dear friends :
    is it will work ??
    Make sure you use the correct Avid Connection manager to mount the workspaces.. and add them as user in the MN5.. then you are set to go..
    MC 3.5.1 Test-Intel Core2Duo 6800,GTS8800 Nvidia,Realtek HD, 21" Samsung display [view my complete system specs]
    Dutch AV forum
