Latest post Wed, Nov 18 2009 10:00 PM by Krishius. 17 replies.
  • Tue, Nov 3 2009 8:55 PM
    • camoscato
    • Posts 6,068
    • Points 72,830
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Media Composer 4.0.3 Released
    Hi all,
    Avid has released the following new editors today, November 3, 2009.
    *              Avid Media Composer v4.0.3 (Mac and PC)
    *              Avid NewsCutter v8.0.3 (PC)
    These are full installers.
    Customers with a valid Avid Support Contract can download/upgrade their editor(s) (v4.0.x/v8.0.x)  on the Download Center (login and password required) and any customers who purchased Avid Media Composer v4.0.x and Avid NewsCutter v8.0.x are entitled to download/upgrade from the avid.com Download Site.
    Note:  Any Academic system that is currently at v4.0.x/v8.0.x can be upgraded to v4.0.3/v8.0.3.
    Download Locations:
    The download files will available in two locations:
    -    Avid Download Center for support contract holders (http://esd.avid.com/Login.aspx?ReturnUrl=%2fDefault.aspx ).  The new editors will be listed inside there respective folders.   Login and password required for access to this site.
    -    avid.com Download Site. The editors will be located here:  http://www.avid.com/register/mcsoft_dl.asp
    SW Licensing and Dongle Upgrade Codes:
    The v4.0.3/v8.0.3 editors are an update to the existing v4.0.x/v8.0.x products and do not require a dongle or SW licensing update.
    Fixes and ReadMe Files
    Avid Media Composer v4.0.3 and Avid NewsCutter v8.0.3 are update releases to the existing v4.0.x/v8.0.x editors.   There are many fixes to this release so customers are encouraged to read the ReadMe document provided with the download and also located on the Knowledge Base prior to upgrading.
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Tue, Nov 3 2009 11:06 PM In reply to
    • editorbelga
    • Joined on Wed, Mar 4 2009
    • Madrid
    • Posts 79
    • Points 1,005
    Re: Media Composer 4.0.3 Released
    quicktime 7.6.4 is supported
    but if you install that, in sorenson 5.1 you can not load the Quictime presets...
    I stick with 7.6.2
    HP XW8600 - 2x Quadcore 3.00Ghz - 8GB RAM - Nvidia Quadro FX3700 - Avid Media Composer 4.0.3 + Mojo DNA - Windows Vista Business 64bit [view my complete system specs]
  • Tue, Nov 3 2009 11:43 PM In reply to
    • sverkalo
    • Thessaloniki Greece
    • Posts 4,786
    • Points 56,995
    You found a problem before even the new version is well released.
    Maybe if you try to reinstall Sorenson?
    Desktop
    Armor 8000/Zalman 600W/Abit IP35Pro/Quad 6600@3G/8G Corsair DDR2 800/Geforce 8800GTS 640@Quadro FX 5600(169.47)/X-Fi Xtreme Music/160WD S2/2x1TB Samsung F1(RAID 0)/Many e-SATA drives/Samsung 203B/Vista Business SP1 64bit/Avid Media Composer 3.1.3 Suite/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    Laptop
    Fujitsu Siemens(Amilo Xi 2528-07)/T8100/3G DDR2/8600M GS 256/Realtek HD/Many e-SATA drives/Optiarc 7540/Optiarc 7240S(USB)/Vista Business SP1 32bit/Avid Media Composer 3.1.3 Suite.
    My Films
  • Wed, Nov 4 2009 2:17 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,025
    • Points 25,875
    • Moderator: MCA PC
    Usually I wait a bit before catching up with upgrades.
    Today is an exception.
    I downloaded and installed 4.0.3!
    I notice that the "Read Me" is for MC 4.0 and not for MC 4.0.3
    I have informed Marianna.
    Regards,
    Douglas
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Wed, Nov 4 2009 5:00 AM In reply to
    • sasha1
    • Posts 252
    • Points 3,315
    From the Readme
    Fixed in v4.0.3
    The following have been fixed:
    ➤ Bug Number: UDevC00128226. The v190.38 NVIDIA driver has been qualified. This fixes
    the “Unable to install fonts” error that occurred on WinXP SP3 systems.
    ➤ Bug Number: UDevC0090818. You might have received an “Exception: FILE_Other” error
    when exporting AAF to a network shared drive. This has been fixed.
    ➤ Bug Number: UDevC00128607. Playing back the Timeline when in MultiCamera mode
    with the DV device attach resulted in an “Exception: ADM_DIO” error. This has been fixed.
    ➤ Bug Number: UDevC00129441. Using Audio Punch-in to create filler at the beginning of
    the timeline would sometimes fail with an error. This has been fixed. This has been fixed.
    ➤ Bug Number: UDevC00130505. Performing a DV capture with the Panasonic AJ-SD755
    deck might have resulted in “ADVAudioDev: TransferSample” errors. This has been fixed.
    ➤ Bug Number: UDevC00131178, UDevC00131974. XDCAM batch imports occasionally
    failed to accept the correct disk. This has been fixed.
    ➤ Bug Number: UDevC00130028. Some AAF sequences did not successfully import into the
    editing application. This has been fixed.
    ➤ Bug Number: UDevC00130757. The Timeline would freeze for approximately 5 to 10
    seconds when performing an audio scrub. This has been fixed.
    ➤ Bug Number: UDevC00130658. After canceling a sequence export and returning to the
    Timeline or Source/Record monitors, you might have received a “Core_unable_to_do” error.
    Fixed in v4.0.2
    5
    ➤ Bug Number: UDevC00129841. When performing a checkin from the editing application
    to Interplay, reference assets were not always checked in. This has been fixed.
    ➤ Bug Number: UDevC00105760. Media appeared as offline when sending to playback.
    This occurred when a P2 clip was placed in the Timeline after an in-progress clip. This has
    been fixed.
    ➤ Bug Number: UDevC00128958. When working in Segment mode, when moving a
    long GOP format clip to a new location, there was a delay in updating the sequence. This has
    been fixed.
    ➤ Bug Number: UDevC00129064. Media received during a transfer while the Audio Punch
    In tool was recording to the Timeline, appeared offline in the Transfer Bin. This has been
    fixed.
    ➤ Bug Number: UDevC00129581. Channel rotations might have occurred when performing
    HD SDI audio capture on the Symphony Nitris. This has been fixed.
    ➤ Bug Number: UDevC00129784. If you made a change to a User setting and then closed the
    project, the User setting change would not stick. This has been fixed.
    ➤ Bug Number: UDevC00129809. The clip gain in the Audio Mixer tool displayed incorrect
    gain values when Command 8 was attached. This has been fixed.
    the full readme is here
    http://cdn.pinnaclesys.com/SupportFiles/attach/README_AvidMediaComposer_v4.0.3_Nov_2_09.pdf
    Dell T3400 - Core 2 Duo 3.00 - 8GB RAM - FX 1700 - Vista Biz 64 - MC 3.5 - RAID 0 of 2 x 1.5TB drives for 3TB internal media drive. [view my complete system specs]
  • Wed, Nov 4 2009 8:16 AM In reply to
    • editorbelga
    • Madrid
    • Posts 79
    • Points 1,005
    sverkalo:
    yes, tried that... default presets of the Sorenson don't even import anymore with 7.6.4
  • Wed, Nov 4 2009 10:32 AM In reply to
    • sverkalo
    • Posts 4,786
    • Points 56,995
    GO back το 7.6.2 as they say.
    Desktop
    Laptop
    My Films
  • Wed, Nov 4 2009 11:01 AM In reply to
    • editorbelga
    • Madrid
    • Posts 79
    • Points 1,005
    yes, did that. Everything fine
    .. as they say... who are 'they'?
  • Wed, Nov 4 2009 12:03 PM In reply to
    • sverkalo
    • Posts 4,786
    • Points 56,995
    Those who are in 4.0.3.
    Don't worry. They are earthed.
    Desktop
    Laptop
    My Films
  • Thu, Nov 5 2009 9:50 AM In reply to
    • Geoffs
    • Joined on Mon, Oct 19 2009
    • Brisbane, Australia
    • Posts 13
    • Points 125
    This is my first time updating AVID and am wondering if I need to deactivate the software before I uninstall? Or can I just uninstall everything (Currently 4.02) and then install the latest build?
    Windows 7/ Vista Dual boot i7 920 6 gig-o-ram 285 GTX Video Card [view my complete system specs]
  • Thu, Nov 5 2009 6:50 PM In reply to
    • erik1185
    • Gaithersburg, MD
    • Posts 771
    • Points 9,605
    You must deactivate the software before installing the newer version.
    Intel Core 2 Duo 3.0 GHZ, 2GB ram, Nvidia Quadro FX 570 [view my complete system specs]
  • Fri, Nov 6 2009 11:09 AM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Cymru/Wales
    • Posts 321
    • Points 3,930
    Just to re-itterate the Read Me in the download is for an earlier version of Avid 4.  Bit of a clanger really - as it suggests older video drivers etc.
    D
    Panasonic HPX301 P2 Camcarder (sic!), MC 4.0.3, Vista 64 SP2, Asus P5K-E Mobo, Q6600 Dual Quad Core @ 2.4Ghz (3.0 Ghz if I'm up against it!), 8Gb 800Mhz RAM Dual channel, C: Raptor (can you hear it?!) Media: 4 x 500Gb SATA Stripe O pairs, P2 archive E-Sata WD x 4, Quadro FX 1500 GFX, Soundblaster Audigy, Mojo SDi.  Sony PVM CRT.  Approved Avid HP 8240 Notebook.
    VIDEO PRODUCTION SOUTH WALES CRACKING PRODUCTIONS
  • Fri, Nov 6 2009 12:11 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 2,061
    • Points 27,445
    I have to keep using the 182 driver for 4.0.3 as I found that the newer driver completely destroyed the OpenGL shader 4 for one of my apps (Vue 8 Infinite). Admittedly, there are many settings that I could have tweaked in the display driver to (perhaps) sort this out but for now, the driver shipping with 4.0.2 seems to work just fine. Mind you, this sort of thing is entirely dependent on the particular card you're using, etc.
    Anyone else have any problems with the driver shipping with 4.0.3?
    Camera(s) Sony HDR-FX1, Canon HV20 | MC 4.0.2 | Vista 64 Ultimate SP2 | System: P5W-DH QUAD QX6700 (2.66GHz clocked to 3.2GHz), 8GB RAM (800MHz), 300Gb... [view my complete system specs]
    Steve
  • Sat, Nov 7 2009 12:00 PM In reply to
    • Sasquatch
    • Nottingham England
    • Posts 561
    • Points 6,705
    caused open GL shader related crash in AE8
    HPXW8400 4gb ram Nvidia FX 1500 MC 4 Adrenaline, HP XW8200 3gb ram Nvidia FX1400 MC 3.5 with SDI mojo, Avid express DV. [view my complete system specs]
    Mike Kruft. Nottingham, UK
  • Tue, Nov 17 2009 11:49 PM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 581
    • Points 6,925
    BarkinMadd:
    I actually did a separate post yesterday, but re-reading this think maybe this was my issue.  Even though the Avid indicated that I need to upgrade the Nvidia driver to 190.xxx I think maybe I should have stuck with 182.xxx.  I had massive lag in the CC and my wacom went sluggish as well.
    Already wasted 3 hours yesterday and had to roll back to 4.0.2.  No more time for testing.
    Ra-ey
    HP 8600 Symphony Nitris DX v4.0.2 Sapphire v2.081 Boris Continuum Complete v5.0.4 AvidFX (Boris Red) v5.8 Heroglyth v2.6 Vitascene v1 Adrenaline... [view my complete system specs]
