Latest post Sun, Nov 22 2009 4:51 PM by GeorgeD. 2 replies.
  • Tue, Nov 3 2009 5:37 PM
    • johnnytex
    • Joined on Tue, Apr 18 2006
    • Dallas
    • Posts 44
    • Points 450
    Metafuse and 29.97
    Can Metafuse convert footage that is shot @ 59.94 or 29.97?
    xw8600 XPPro 4g ram fx 3700 Media Composer 4.0.2 AvidFX ver5.1.5 [view my complete system specs]
  • Tue, Nov 3 2009 8:54 PM In reply to
    Re: Metafuse and 29.97
    I don't believe so. I just needed to do this myself the other day and could not figure out a way to do it. I did not consult the manual so you may want to read and see if there is a workaround.
    Igor Ridanovic
    www.HDhead.com
  • Sun, Nov 22 2009 4:51 PM In reply to
    • GeorgeD
    • Posts 120
    • Points 1,460
    It will convert anything to 24p, frame by frame. With Avid 4 you can open the 24p clip in your NTSC project, promote the motion adapter and adjust the speed. I have converted 3kP50 footage to PAL like that. However the audio was drifting out of sync. Most likely a Red problem since Metafuze doesn't resample audio.
