Latest post Tue, Nov 3 2009 3:34 PM by Job ter Burg. 3 replies.
  • Tue, Nov 3 2009 10:26 AM
    • LDani
    • Joined on Tue, Jan 10 2006
    • Hungary
    • Posts 32
    • Points 370
    Windows share vs. Unity share for projects?
    In an Avid unity environment I made a windows share for the projects. I think it is a more sophisticated solution, because:
    • -everybody needs Project volume, so you don't need to always connect it with connection manager
    • -you can use some Windows Server functionality:
    • shadow copy: you will have a copy of your projects on your own timebase
    • screening: you can prohibit to copy mediafiles, documents, music, etc..(depends on the file extension) on your projects volume. It's a really nice feature!
    • quote: you can add quotes, and you will get an email if your free space falls under a threshold
    • ntbackup: you can schedule a daily, weekly backup of your projects
    • -you can monitor the status of your volume using your favorit open source SNMP solution. For example: Zabbix, Cacti, etc…
    BUT, there is a big problem with this usage: the unity shared bin locking method is not working! :( :( So if you open a bin more than one NLE, only the first can save data in it: It seems the others correctly saved, but there is no warning message, no error, and there is no data in the bin!
    Is it possibly to set manually somewhere the unity locking mechanism on my windows share? (the windows share is located on the system drive D: on my avid unity v5)
    If there is no possibility to set it, I will be very sad, because I have to use the old way, Avid unity Shared volume, without the mentioned really cool features of the windows shared folder.
    Please send me suggestions, opinions about this workaround!
    Thank you,
    Daniel
    CURRENT SYSTEM: 3x Avid Media Composer v3.5 NitrisDX on HP z400 1x Avid Media Composer v3.0 NitrisDX on HP xw8600 1x Avid Symphony v1.8 / DS v8 Nitris... [view my complete system specs]
  • Tue, Nov 3 2009 1:48 PM In reply to
    Re: Windows share vs. Unity share for projects?
    Well, there you have the biggest benefit of Avid Unity: true project & bin sharing.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Tue, Nov 3 2009 2:25 PM In reply to
    • LDani
    • Hungary
    • Posts 32
    • Points 370
    This means there is no way to setup a true bin sharing, when I using Windows shared folder?
  • Tue, Nov 3 2009 3:34 PM In reply to
    Pretty sure that only Avid Unity gives you true project & bin sharing. That is a Unity feature, the whole multiple user acces with bin locking.
