In order to make my show fit on a dvd I encoded the audio at 256. I compared the original wave file to the new ac3 file and the original wave file was almost 2x as loud. Is this typical?
K
What did you use to encode the ac3? Did it have a normalise or peak limit option?
Was the original wave monotracks? or a stereo file?
Thanks for the continued dongle support
I used "ffmpeggui"
I don't think there are any normnalise or peak limit options with this program. The settings were "bitrate" - 256; format - AC3; Sampling - 48000; and channels - 2.
The original audio from my timeline had 3 tracks - each track was panned center (so that when you played the single track the 2 audio meters bounced). Each track was bumped up to about +5 so that the yellow bars showed. I exported these 3 tracks as stereo, wave, 48kHz. I then encoded with ffmpeggui. Then I compared the exported (wave) file to the converted AC3 file using Goldwave. I placed the waveform plots one on top of the other. The original wave file was almost 2x as loud.
I found a way around the problem by bumping the original audio even higher but I don't think this is the right way to do it.
