Latest post Mon, Nov 2 2009 3:49 AM by Pixel Monkey. 9 replies.
Page 1 of 1 (10 items)
  • Sun, Nov 1 2009 9:23 PM
    • Pixel Monkey
    • Everywhere (thanks to FTP)
    • Posts 155
    • Points 2,155
    Crying [:'(] Not shot in a format current MC or FCP can see!
    SONY HDV camera (Z5U) shot 1080i 24p. Using a SONY Z7U as a deck. Firewire. Having capture issues - same issues on MCA (HP8400) at work and Mac Pro (intel quad core) at home. Both systems up-to-spec.
    Have newest versions of MS and FCP. Neither can see this format without burping timecode error messages every two seconds. In short, I've created EVERY project type in MC and tweaked every possible setting in FCP's video settings.
    Totally able to capture 30i NTSC no problem... but obviously I'm going to have to online this thing in HD.
    Clues? I'll even accept After Effects as an answer at this point!
    Work mcA-283 HPxp8400 QuadroFX1500 medianet511 on interplay123 Home mcS-403 2x2.66 DC-IntelXeon with 3gb 667 DDR2 FB-DIMM [view my complete system specs]
    Pixel Monkey / Chris Bové
    Pictures say 1000 words. Editors give them meaning.
    alwaysediting.com (website)
    youtube.com/alwaysediting (My Channel)
    wnyppg.org/ (Avid Users Group)
    http://www.youtube.com/page11music (The old band... miss those days!)
  • Sun, Nov 1 2009 9:27 PM In reply to
    • gumbycat99
    • Joined on Fri, Jun 6 2008
    • Auckland, New Zealand
    • Posts 257
    • Points 3,060
    Re: Not shot in a format current MC or FCP can see!
    did you try turning the timecode track off when you digitise? Not sure about the 24p format, but that is my trick for most other HDV digitising.
    cheers
    Campbell
    3.0.5 on a mongrel PC, Win XP SP3, QT7.5, Quadro FX1400, 2Gb RAM, 2x500Gb internal SATA drives, Macdrive 7 and a Mac formatted WD 250Gb laptop drive in... [view my complete system specs]
  • Sun, Nov 1 2009 9:30 PM In reply to
    Pixel Monkey:
      I don't think it's possible to have 1080i/24p.  The i and p conflict.  You can have 1080p/24 or 1080i/60 but not 1080i/24p
    Pixel Monkey:
    Firewire.
    Pixel Monkey:
    Pixel Monkey:
    Have you tried capturing in a 1080p/24 project?  Also, what kind of storage are you using?  FireWire is notoriously bad for TC dropouts (IME), which is part of the reason I avoid HDV material over FireWire.
    Can you try a deck with Serial Control and see if the TC issues persist?
  • Sun, Nov 1 2009 9:47 PM In reply to
    • MichaelP
    • Boston
    • Posts 1,751
    • Points 21,670
      Moderator: Film
      Moderator: MetaFuze
    You'll have to go 1080i project if the footage has 24 with pulldown. Timecode errors are proably due to the the 30 and 24 fps conflict.
    Michael
    HP 8600 Symphony Nitris DX v4 || MBP 15" Media Composer v4 [view my complete system specs]
    ____________ Anything 24fps
  • Sun, Nov 1 2009 10:28 PM In reply to
    • Pixel Monkey
    • Posts 155
    • Points 2,155
    Wow - lots of folks bored on a Sunday! Didn't expect to hear boo until tomorrow.
    Yeah the display on the Z5U actually reads HDV1080i 24p. Stunned me to. Shooter in California insists myself and three other editors on this project are dumb for not being able to use these five tapes.
    Tried 1080p project. Refuses to see video, probably because raster size of the HDV stuff is 1440x1080.
    Tried 1080i project. Only successful when switching to 30i. Timecode issues in HD prevent capture.
    Until I find a solution, I'm going to move forward with the DV25411 stuff. There's a good chance I'll only need 30-40 seconds of the footage in the final online in a month. Perhaps any of you know of a solution? Perhaps MC v4.0.4 will support? Perhaps SONY Z5U cheated for that one camera and made a 1080i 24p format that bombed so they discontinued
    Help? No idea?
  • Sun, Nov 1 2009 10:39 PM In reply to
    • gumbycat99
    • Posts 257
    • Points 3,060
    is it possible that there is some proprietary software that is supplied with the camera that you can use? i know with consumer level cameras there's usually a cd with some software for editing. maybe there is something from sony you can get that you can export a quicktime from...
  • Sun, Nov 1 2009 10:51 PM In reply to
    • Pixel Monkey
    • Posts 155
    • Points 2,155
    I'll definitely chase that idea. Good one!
    Normally I'd stick the HDV tape in one of those DVC_Pro adapters so I could bring it in HDSDI from either our 1700 deck or our 1400... However neither one understands the 1080i 24 not 1080p. Doh!
    PS - tried 720p but the 1280 raster makes for a nice error message of "...video no loner coming into the system."
  • Mon, Nov 2 2009 12:28 AM In reply to
    • bobcat
    • Joined on Thu, Jul 20 2006
    • New Mexico, USA
    • Posts 319
    • Points 3,730
    I believe the Sony Z5 records both Native progressive and progressive via Progressive Segmented Frame (PsF) which records to an interlaced signal. Not sure how to handle the PsF in Avid. No experience there.
    But that may be how you got 1080i 24PsF.
    (System #1)HP 8200,dual 3.4,quadro 1400, 2gb ram, 160gb boot drive, 250gb Sata internal, Avid MC 3.0, Caldigit HD Element 4TB Raid Array w/ Raid Card ... [view my complete system specs]
  • Mon, Nov 2 2009 12:35 AM In reply to
    • MichaelP
    • Boston
    • Posts 1,751
    • Points 21,670
      Moderator: Film
      Moderator: MetaFuze
    The fact that it is listed as 1080i means that the 24fps is inserted with a pulldown into a 59.94 interlace format which is why 1080i should work. Don't know what is up with the timecode. Try turning the TC track off in the capture window to see if it can be captured that way.
    Michael
  • Mon, Nov 2 2009 3:49 AM In reply to
    • Pixel Monkey
    • Posts 155
    • Points 2,155
    My thoughts exactly... but no dice. It's the same on all five tapes shot over three weeks. Same camera, same shooter. When capture window is open and timecode is displayed, the seconds "flutter". Two seconds forward, one second back for a few frames, repeat.
    When in capture mode, video is seen just fine. Audio is there too. Try to capture in any which way, and...nope.
    Same with Final Cut too though, which makes me think that it's some nutjob format in that particular camera.
    Camera plays other tapes (1080i/60 and 720p24) just fine.
    MODS - worth promoting? If bobcat is right with PsF on Z5U, then it should at least cross the desk of those at Avid who integrate decks/cams.
    I'll start a thread on a few of COW's forums too.
