Latest post Sun, Nov 1 2009 11:56 PM by jwrl. 4 replies.
  • Sun, Nov 1 2009 8:40 PM
    • adamsonn
    • South Africa
    • Posts 337
    • Points 4,945
    Deleting an effect off a collapsed track - can someone check this?
    Hello
    I have 6 video tracks with various effects applied to each of the Video tracks - I have collapsed these all into a single track. (Using the collapse button)
    When I apply an effect onto the collapsed track and then try to delete the effect it deletes either the entire clip (i.e all collapsed tracks) and leaves an empty space or it deletes all the video tracks inside the collapsed track except the bottom track - this behaviour is when deleting a Boris effect.
    Is this normal behaviour - if so how does one delete an effect applied to a set of collapsed tracks?
    Help!
    MC3 machine: Intel Pentium 3Ghz Duo Dual Core (E8400) Asus P5QL-EM Motherboard 1*160 Gb SATA drive - partitioned to C (OS and programs) and D (data... [view my complete system specs]
    Neil
  • Sun, Nov 1 2009 8:52 PM In reply to
    • adamsonn
    • South Africa
    • Posts 337
    • Points 4,945
    Re: Deleting an effect off a collapsed track - can someone check this?
    Hello
    Please ignore this post - I have discovered that one needs to hold down the alt key when adding effects to a collapsed set of tracks.
    Holding alt when adding further effects allows them to be deleted from the collapsed master trackwithout deleting the entire clip.
    Neil
    Neil
  • Sun, Nov 1 2009 8:56 PM In reply to
    adamsonn:
    That's because the Collapse is an effect (Submaster) and in order to apply two effects, you need to Nest them.  The quickest and easiest way to Nest an effect is to hold ALT while applying it.
  • Sun, Nov 1 2009 9:02 PM In reply to
    • adamsonn
    • South Africa
    • Posts 337
    • Points 4,945
    Yes thanks Kenton
    Interesting though that when you try to drag an effect onto a standard clip that has an existing effect you get a blip and an error message saying "Effect Does not Apply"
    Yet for the collpased track (submaster) you can just drag the effect onto the sub master clip and it does apply it - you just cannot delete it unless you used the correct method - i.e holding down the alt key.
    Neil
    Neil
  • Sun, Nov 1 2009 11:56 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 4,242
    • Points 48,755
    I suspect that was done because it's an easy way to set up an effects group to then be nested inside another effect or effects.
    MC 4.0.3 - Asus P6T Deluxe V2 mobo - Intel i7 920 2.66GHz - nVidia Quadro 1700 - 12 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro firewire... [view my complete system specs]
