Latest post Wed, Nov 4 2009 9:31 AM by jijilafrite. 3 replies.
  • Sun, Nov 1 2009 7:57 PM
    • jijilafrite
    • Joined on Mon, Oct 15 2007
    • PARIS
    • Posts 29
    • Points 385
    Anyone Works /edit with the CANON 5DMKII?
    Hi, It's been a few months I edit my 5D files with AVID; it works well; I don't really understand why everyone's talks about the Final Cut workflow, wich is quite the same in AVID ( FCP: transcode your H264 in Prores 422)(In Avid: import directly your H264 in DNXHD, yes you need a lot of diskspace ). It's true that in FCP you can use color wich is very powerful, but?
    Well, I feel satisfied with the Avid worflow and wanted to get some other experienced from you guys, on black, gamma, colors, export, sound etc. good or bad expérience,  works well or not for you. It seems that only a few peopole use AVID to edit those files. Would be great to have some feedback from AVID too as the 5D/7D/1D gets more and more common with video!
    AVID MC 4.O PC Dell Precision 690-Dual Dual Intel Xeon 5160 (3.0GHz,1333Mhz,4MB) 750W 4GB DDR2 667 Quad Channel FBD Memory 4x300GB (10,000rpm) SAS Hard Drive NvidiaQuadro FX3500 (MRGA13) Sound Blaster X-Fi Xtreme 30" (3007WFP-HC) Wide
    Filed under: ,
  • Sun, Nov 1 2009 11:46 PM In reply to
    • lmerino
    • Joined on Mon, Dec 19 2005
    • Chicago
    • Posts 316
    • Points 4,285
    Re: Anyone Works /edit with the CANON 5DMKII?
    I have completed several projects shot with the 5Dmk2 on Avid.  Everything does seem to work just fine (in NTSC land).  I recently upgraded to MC4.0 and see that it now has 1080p as well, so I'm excited to try using that (as opposed to 1080i from previous MC versions).
    Dell Precision M90 Win7 4GB RAM MC 3.1 [view my complete system specs]
  • Mon, Nov 2 2009 4:45 PM In reply to
    • jijilafrite
    • PARIS
    • Posts 29
    • Points 385
    Great to have some news, I can see some user uses AVID to edit the files, I'm actually editing withe the new 1080 p, works great.
    The only thing is importing my files in 220 resolution is too much, my computer gets slow on playback..I have to deal with 145...
  • Wed, Nov 4 2009 9:31 AM In reply to
    • jijilafrite
    • PARIS
    • Posts 29
    • Points 385
    No one else uses AVID for 5D? I guess we are only 2 ?!! Come on  guys, gives you impressions, I'm sure we can improve the workflow together and find great tips! Would be great to have some impressions by an Avid moderator too!
