Latest post Mon, Nov 2 2009 2:48 PM by GusC. 3 replies.
  • Sun, Nov 1 2009 2:27 AM
    • tmca50
    • Posts 35
    • Points 515
    Global Chroma Control?
    We have a feature documentary beautifully finished in DS in Sweden. I’m in Hollywood now to try and sell it. Watching the finished DVD on American TVs it seems to lack color when compared to other programming. I have the entire project on a hard-drive but our budget is exhausted. I’m wondering if a DS studio can open the project and raise the color saturation slightly across the board with one global setting; i.e. very easily (and cheaply) without negatively affecting all the great work that has been done?
    Thank you in advance for your time.
  • Sun, Nov 1 2009 11:58 PM In reply to
    • M-Edit
    • Joined on Thu, Jan 29 2009
    • Posts 79
    • Points 915
    Re: Global Chroma Control?
    Hi, don't know if I have any answer to you at all,
    but since no one else seems to be barking in,
    I'll give a shot a it. Or at least to the "problematics"
    that can be involved.
    First of all, you can put a "colour correction effect"
    at the top-most, i.e SFX-level, which effects all the
    layers beneath.
    But there are some "but's" to how successful opening
    a DS project, on another DS-system, can be.
    You have to check if you used any plugins in the DS
    in Sweden, and if that's the case, that same plugins have
    to be on the DS you open the project up on in the States.
    Some strange and really timeconsuming artifacts can
    come from not having the plugins installed. And in
    timeconsuming I mean that it can take a hell of a time
    for the guy opening the project to come to a conclusion
    of what the problem is. And that could obviously cost
    some "pretty pennies" before anything "real" even have
    been done to the program.
    Which DS-version the project is created in and then
    opened up in could also be more of less of an issue,
    depending on if you just have a copy of the project or
    if the project has been properly archived. Archiving
    (most if the time) gives a better "latter-version
    compability".
    Sorry for the "negative" attitude, but I just want you to
    be cautious since you mention that your "budget is
    exhausted". Dollars move rapidly out of your wallet
    when your "out in DS country". Or any other "high-end
    finshing suite" facility, of any brand, for that matter.
    But ok, let's say that you got the project "in" and corrected,
    then there are some options to get out of there:
    1. Exporting to a high-rez format (for example QuickTime),
    which means you'll suffer a render pass, and then that QT-file
    has to converted to a MPEG-2 file, which then has to be
    authored to a new DVD. Since I guess it's DVD you want
    to end up at again?
    2. Output to tape. Don't think that this is a realistic option,
    but it depends on how the facility house you end up at will
    work. This also then has to be captured to preferrably MPEG-2
    and authored
    3. Output from the DS directly to a capture device that can
    convert from SDI to a MPEG-2 file in realtime. And then author it.
    The latter two "real-time-outputs" will probably also need render
    passes before they can be output.
    Anyway as I see it the winner of the "less-timeconsuming-contest"
    would be #3.
    There is also a "sneak"-option that I think should be considered
    when the budget is tight.
    And that is to rip the DVD-content to a MPEG-2-file or maybe
    a High-rez QuickTime or AVI, and then make the changes in
    some program, like Premiere, Vegas or the like and then
    export (and yes, recompress) to a new MPEG-2, and then
    re-author.
    This is something you even can manage on a "not-so-hefty"
    laptop if you have the right programs installed.
    It might seem strange to give this type of "cheap"-solution advice
    on a high-end forum as the DS forum, but I see not reason to
    blow a probably non-existant budget even further into utopia.
    Anyway, good luck and I hope some of these words helped you get
    some insight on to which route to embark in "solving this matter".
    //mike
  • Mon, Nov 2 2009 10:34 AM In reply to
    • tmca50
    • Posts 35
    • Points 515
    Thanks Mike!
    I'll output the final to DigiBeta as my master, need it for festivals and such. I have a pretty good price in Hollywood to run off DVDs from BigiBeta, not sure what compression he uses but it looks OK.
    So I understand that assuming the DS systems are compatible a general increase in color is pretty simple. Thanks for that info!
    BR/Tom
  • Mon, Nov 2 2009 2:48 PM In reply to
    • GusC
    • Burbank, CA
    • Posts 395
    • Points 4,755
    • Moderator: Avid DS
    tmca50:
    I suppose you could dub that Digibeta with the Chroma pot turned up a snort on the playback machine.  Or try and book 2 hours of linear SD time to do it.  That will be far less than booking 3+ hours of DS time.
