Latest post Sun, Nov 8 2009 1:52 AM by tompearson. 2 replies.
  • Sun, Nov 1 2009 12:43 AM
    • tompearson
    • Joined on Thu, Mar 1 2007
    • Wayzata MN
    • Posts 579
    • Points 6,245
    p 2 wont play
    after loading some p2 footage  i import them into a bin  they all show up  and when i click on one a  error comes up  " clip frame rate (59940)does not match the project frame rate (2997)  the thing is that it is a
    1080/5994  project with a standard raster
    any thoughts
    asus mb p5wd2 dualcore 3 gig intel cpu's 4 gig crucial ram nvidia quadro fx 3500 1 tb wd sata 7200 raid 0 seagate 160 gig sata 7200 os drive mojo command... [view my complete system specs]
    Tom Pearson Director Hollywood-sounds.com
  • Mon, Nov 2 2009 4:15 AM In reply to
    • gumbycat99
    • Joined on Fri, Jun 6 2008
    • Auckland, New Zealand
    • Posts 257
    • Points 3,060
    Re: p 2 wont play
    was it shot progressive or interlaced? have you tried creating some different projects with alternative frame rates just to test?
    it sounds like it should work from your description, but there may be something if it was shot progressive because that would be recorded PsF.
    can't think of anything else to try.
    cheers
    campbell
    3.0.5 on a mongrel PC, Win XP SP3, QT7.5, Quadro FX1400, 2Gb RAM, 2x500Gb internal SATA drives, Macdrive 7 and a Mac formatted WD 250Gb laptop drive in... [view my complete system specs]
  • Sun, Nov 8 2009 1:52 AM In reply to
    • tompearson
    • Wayzata MN
    • Posts 579
    • Points 6,245
    Re: p 2 wont play
    i found out the problem camera person recorded first day at 720  and the rest at 1080 now using a new camera person  thanks for your suggestion
