Latest post Sun, Nov 1 2009 5:32 PM by Joachim Claus. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Oct 30 2009 4:56 PM
    • patersonap
    • Joined on Wed, Aug 29 2007
    • UK
    • Posts 19
    • Points 325
    Sorry to bring it up again - No Video Playback
    Hiya I've had some major issues with this in the past:
    Whenever I play anything the audio plays but the Video stays on whatever frame its in in the timeline. I can move the video manually so all the video is there.
    I have tried importing and recapturing files to see if it is the files, but still no luck. I have tried important 2 jpegs and putting them on the timeline, but still no luck.
    I've just upgraded to windows 7 (64bit) and installed Media composer 3.5
    I have a NVIDIA Quadro FX 3500 installed with a 169.47 and Version 7.5.5 of quicktime.
    I have tried reinstalling the drivers for these
    I have tried the video display settings on both my graphics card and software OpenGL
    I have tried turning on and off the legacy overlay feature
    This problem has been driving me mad for ages if anyone has any ideas please please help!
    thanks
    Ali
    Avid Media Composer V3.5 AMD Phenom(tm) 9950 Quad Core Procesor 2.60 GHz 8.00 GB RAM 64-bit operating System NVIDIA Quadro FX 35000 [view my complete system specs]
    Filed under: , ,
  • Fri, Oct 30 2009 6:12 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    Re: Sorry to bring it up again - No Video Playback
    Ali:
    The Windows 7 OS has not yet been certified for use with Avid software. You should be running Windows Vista Business or Ultimate 64, or Windows XP Pro SP 2 32 bit.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Fri, Oct 30 2009 7:07 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,822
    • Points 201,035
    ...and when you do have this issue, it's because the Video Card Drivers are not compatible. Which would make sense for Win 7.
  • Fri, Oct 30 2009 7:41 PM In reply to
    • patersonap
    • UK
    • Posts 19
    • Points 325
    When i had vista installed i still had this problem - I'm going to rebuild with vista 64 bit, but if teh problem persists, what would you recommend?
  • Fri, Oct 30 2009 7:47 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,822
    • Points 201,035
    1. Check that your Video Card is supported
    2. Check that your Video Driver is supported
  • Sun, Nov 1 2009 5:32 PM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 187
    • Points 2,265
    patersonap:
    When I installed Windows 7 64-bit, I had the same problem with Media Composer 3.5.4. Windows auto-update has then proposed a new nvida driver, which i installed, and the problem disappeared. BTW, I am now running the latest W7 driver for Quadro whitout any problem. It is version 191.00 downloaded from nvidia.
    Joachim
    SuperMicro Workstation 7046A-3 Dual Xeon (Quadcore) X5550 2.67GHz 12 GB RAM PNY FX1700 Soundblaster Audigy 2 ZS Pro 4 SAS HDD's 300GB 15k (1 for OS... [view my complete system specs]
    Joachim Claus
