Latest post Fri, Oct 30 2009 7:09 PM by BLKDOG. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Oct 30 2009 4:42 PM
    • Avidon
    • Joined on Mon, Oct 27 2008
    • Posts 70
    • Points 875
    Upgrading from 3.5.4 directly to 4.0.2
    possible?
    Or do i have to upgrade to 4.0 first.
    Also, for upgrade, is clean install still recommended?
    And for a clean install, is manual uninstall recommended over uninstalling using avid utility?
    I found the following article in the knowledge base for step by step directions to manually uninstall 3.x and to manually remove certain files.  Just wanted to confirm if this article is up to date and if I can follow these steps.
    http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=275029
    Thanks.
  • Fri, Oct 30 2009 7:09 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,836
    • Points 201,220
    Re: Upgrading from 3.5.4 directly to 4.0.2
    You can go right to 4.0.2 seeing as 4.0 was never actually released. We went directly to 4.0.2 for the first release. Give us a buzz if you have any problems.
