Latest post Thu, Oct 29 2009 10:27 PM by Butcher. 0 replies.
Page 1 of 1 (1 items)
  • Thu, Oct 29 2009 10:27 PM
    • Butcher
    • Joined on Mon, Apr 17 2006
    • Evansville, IN
    • Posts 1,331
    • Points 16,955
    When opening nested effects on timeline, allow CC
    If you have nested effects on a clip you can go into effect mode and double click them to open the nest.  Very useful.  You can then add effect inside the nest and see the total effect of all effects (easier and faster than stepping in and stepping out).
    However, you can't go into color correction mode, open the nest, and correct the source.  The only way to do that is to step into the effect, which means you can't color sample lower layers, or see how the CC is affected by other effects in the stack without stepping out, viewing it, stepping in - making an adjustment, stepping out - etc...
    I'd like to be able to open a nest until I get to the source layer (no effects) and color correct, seeing the composite of all other effects as I adjust, as well as be able to sample higher and lower tracks for color matching.
    Thanks.
    Michael
    Dell Precision 490 Dual 3.2GHz Dual Core Processors (Hyper Threading disabled) 4GB RAM nVidia Quadro FX3450 driver 169.47 (nVidia driver supplied by... [view my complete system specs]
