Latest post Wed, Nov 4 2009 2:15 AM by BrittaGL. 7 replies.
  • Thu, Oct 29 2009 6:18 AM
    • BrittaGL
    • Joined on Thu, Oct 29 2009
    • Posts 4
    • Points 30
    Avid Registration
    Hey, I got Avid a few months ago, and registered it online. Then the other day I got a sound card for my computer, and opened Avid and it asked me to register it, again. I went online, and it said I had already used my 1 registration for it. But it's the same computer, I just put a sound card in.
    Any help getting Avid working again would be great.
    ~Britta
  • Thu, Oct 29 2009 7:19 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 3,108
    • Points 35,510
    Re: Avid Registration
    Could you explain what happened, there is quite a difference between unlocking Media Composer using your software key and registering your version at the Avid website.
    Updating your hardware shouldn´t affect your software key, it should still be there in your license folder, that is, if the folder haven´t been removed of course.
    MC 4,03 ( Liquid 7,2 ) V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 8 GB, PNY Quadro 1800, Soundblaster X-Fi... [view my complete system specs]
    Tomas
  • Thu, Oct 29 2009 8:07 AM In reply to
    Have you perhaps added an internet connection that wasn't there when you first activated/registered? This happened to me.  I registered all my Avids, and then briefly connected my Nitris machine to my mobile phone to register Sorenson Squeeze. Normally none of my Avids are connected to the internet. I didn't remove that Nokia connection setting and when I tried to fire up MC again it said it was unregistered. Took tech support a while to figure out that the extra internet connection did actually influence MCs registation/activation setup.  I needed to delete a couple of files, do the activation again and then everything was up and running again
    Avid Unity MediaNetwork 5.0.1 Fibre Channel | Avid Media Composer 3.5.9 Nitris DX HP xw8600 nVidia FX3700 WinXP SP2 Quicktime 7.6 1TB internal... [view my complete system specs]
  • Thu, Oct 29 2009 8:21 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,401
    • Points 16,040
    To add to CorneScheepers: could it be that Your system has two network cards and when You installed the sound card You moved the network cable from one port to the other?
    MC 3.5/Mojo, Vista 64 biz, Gigabyte GA-EP45T-EXTREME, Intel Q9450, 8 GB ram, Pyro 64, Quadro FX 1700, 2 x 1TB drives (raid 0) for mediafiles + G4 MacBook... [view my complete system specs]
    peace luca
  • Mon, Nov 2 2009 2:34 AM In reply to
    • BrittaGL
    • Posts 4
    • Points 30
    Ok so I installed it a while ago, and I needed to connect to the internet, to Unlock Media Composer, which I then did using a software key that I got from the website after writing my System ID and Serial number.
    It worked fine. Then I opened it after putting the new sound card in, and a popup windows comes up and says "KCAV: Activation Code Validation Failed", and wants me to connect to the interner again to get a code to, um, activate it.
  • Mon, Nov 2 2009 6:23 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,108
    • Points 35,510
    Could you describe your install procedure of the card, did you do it yourself, what card is it and did you install any software brought together with the card or only the drivers.
    edited..  and of course, to help us to help you better, please add your system specs to your profile
    Tomas
  • Wed, Nov 4 2009 2:14 AM In reply to
    • BrittaGL
    • Posts 4
    • Points 30
    This may be what happened. I first went online with my Desktop through
    a flatmate's broadband. He's since left, and we have a different
    internet connection which my desktop it not hooked up to, so I clicked
    "Activate avid using internet on another computer", and this is when
    it said it had already been registered. On the other hand, it
    shouldn't have asked me to re-activate Avid in the first place. I
    removed the first internet connection from my desktop ages ago and it
    worked fine when it wasn't online.
  • Wed, Nov 4 2009 2:15 AM In reply to
    • BrittaGL
    • Posts 4
    • Points 30
    Hm, no we didn't move any cables when we put the sound card in.
