Latest post Thu, Aug 5 2010 1:31 PM by bgolden. 13 replies.
Page 1 of 1 (14 items)
  • Wed, Oct 28 2009 5:17 PM
    • JacobsFilm
    • Joined on Wed, Oct 28 2009
    • Posts 5
    • Points 65
    Vista Ultimate doesn't see my JVC BR-HD50
    I have the Windows Vista Ultimate 64 OS and I cannot get the computer to see or recognize my JVC BR-HD50 (an HDV deck) when I hook-up the firewire cables.  I've tried multiple ports and different cables.  I've also tested other firewire devices like a external hard and it seems to recognize that with no problems.  PLEASE HELP!! THANKS!
    Filed under: , , , ,
  • Wed, Oct 28 2009 5:30 PM In reply to
    • Posts 10,898
    • Points 226,990
    Re: Vista Ultimate doesn't see my JVC BR-HD50
    Need way more scoop here.....
    what editor and version?
    What CPU? Cards installed?  slots?
    what format are you trying to see?
  • Wed, Oct 28 2009 5:53 PM In reply to
    • JacobsFilm
    • Posts 5
    • Points 65
    I have Media Composer (Software only) version 4.0 installed on Windows Vista Ultimate.  My tapes are HDV which were shot on HD100 and HD200 cameras from JVC.
    Intel Core 2 Quad Processor Q6600
    NVIDIA GeForce 8500 GT graphics card
    4GB system memory
    I have an older version of Xpress Pro on my old laptop which runs Windows XP and it will see the deck, but the graphics card and the older Avid software won't let me get the video ingested.  This is why I think the problem is between the deck and the computer.
  • Wed, Oct 28 2009 6:00 PM In reply to
    • JacobsFilm
    • Posts 5
    • Points 65
    The processor is 2.4  Ghz
  • Wed, Oct 28 2009 6:26 PM In reply to
    • the_dark
    • Joined on Fri, Aug 17 2007
    • Posts 165
    • Points 2,240
    I know you said you tried firewire hard drive on the Vista machine, but have you tried a different deck on the Vista machine? Just to see if any deck will work.
    I know the JVC BR-DV3000 deck was suddenly incompatible with Windows starting with XP SP3. Windows just wouldn't even acknowledge the presence of the deck. I do hope this isn't what happened with your JVC BR-HD50.
    Good luck.
    Charles
    Dell Precision T3600 Intel Quad Core Xeon E5-1607 3.06Ghz 8GB Memory (4x2GB) 250GB System Drive 500GB to 1TB Media Drive nVidia Quadro 2000 Dell... [view my complete system specs]
  • Wed, Oct 28 2009 6:55 PM In reply to
    • JacobsFilm
    • Posts 5
    • Points 65
    Thanks Charles, but I don't have access to a different deck right now.  I may be able to get my hands on one, but I'm not sure when that would be.
  • Thu, Oct 29 2009 7:27 AM In reply to
    this deck is known for being problematic. JVC has released several firmware updates.
    I haven't used one for a long time and never on vista. But you could check if JVC has again released any new firmware for this deck.
    good luck
    Jeroen van Eekeres
    www.mediaoffline.com
  • Thu, Oct 29 2009 12:40 PM In reply to
    • Swil
    • Australia
    • Posts 498
    • Points 6,455
    I've had issues with my JVC HD101E not showing up - solved them by manually picking the driver for it. Go to your Device Manager, see if it's listed in there as something generic like "AV/C Subunit". Go in and pick Update Driver and manually select one from the list of already existing drivers. There should be a generic sounding JVC one. Try that.
    3.40GHz Core i7-2600K | 24Gb RAM | GeForce GTX 660 Ti | Blackmagic DeckLink Mini Monitor | Presonus AudioBox 22VSL | Windows 10 because I'm mad like... [view my complete system specs]
  • Thu, Oct 29 2009 6:47 PM In reply to
    • JacobsFilm
    • Posts 5
    • Points 65
    Yeah, doesn't even show up in my device manager.
  • Tue, Dec 15 2009 7:01 PM In reply to
    • Pinek
    • Joined on Wed, Jan 7 2009
    • Poland
    • Posts 111
    • Points 1,225
    my br-hd50 work in XP SP 3, but now.... upper system avid don't recognize.
    I link by Mojo, JVC not work, Camcorder SONY DSR-570 connected and work
    but system recognize JVC as AV Device,
    Workstation: AMC 8.3, Windows 7 64-bit ultimate, 4,0 Quad Core, 8 GB RAM, 4 x 1,5TB internal HDD, Nvidia Quadro 4800, LSI HBA, LG Bluray, MOTU HD-SDI.... [view my complete system specs]
  • Tue, Dec 15 2009 7:23 PM In reply to
    • Pinek
    • Poland
    • Posts 111
    • Points 1,225
    Yeee
    Works... i change system driver from AV Device to JVC Camcorder device and Avid WORKS with BR-HD50 and Mojo SDI
  • Wed, Aug 4 2010 11:06 PM In reply to
    • bgolden
    • Joined on Wed, Aug 4 2010
    • Posts 2
    • Points 20
    I have a similar problem. I have a JVC BR-HD50 and a Panasonic AG-HVX200P camera. My Windows 7 64bit doesn't see either of the devices. I'm not following how you were able to get Windows to see your equipment. Run that past me again so I don't pull out the rest of my hair.
    Filed under: , ,
  • Thu, Aug 5 2010 7:57 AM In reply to
    • Pinek
    • Poland
    • Posts 111
    • Points 1,225
    and remember, change firewire 1394 drivers to LEGACY driver
  • Thu, Aug 5 2010 1:31 PM In reply to
    • bgolden
    • Posts 2
    • Points 20
    Would it help if I put an adapter on the end of my firewire cords changing them to USB? or would that slow the process down or cause damage to my devices?
