Latest post Wed, Nov 25 2009 3:32 PM by camoscato. 17 replies.
  • Wed, Oct 28 2009 2:03 PM
    • btwien
    • Joined on Thu, Jan 15 2009
    • Mali, West-Afrika
    • Posts 79
    • Points 1,230
    Soft glow transition
    Hello all,
    Do not know if you are familiar with the serie " Burn Notice", but they use one transition quite often.
    It is as if there is a lot of hightlight put in over time and then dissolves into a new shot kind of...
    Hard to explain (in English) I guess...
    Would that be done with one of the effects already in MC are should it be done with keyframes / time?
    Thanks for your input!
    MC 4.0.2 Academic Version QT 7.6.2 Working with: PC, Windows XP Professional 2002, SP 3 AMD Phenom (tm) 9750 QuadCore Processor 2.41 GHz, 2.75 GB of... [view my complete system specs]
  • Wed, Oct 28 2009 2:09 PM In reply to
    Re: Soft glow transition
    I haven't seen the show, though there are a few ways to do this.
    Quick way would be to use BCC "Glow" as a transition, fade it in and out. Another way is to use a dip to color and make the dip white.
    :: Work - Symphony Nitris DX 3.5.1, HP xw8600 :: Home - Media Composer 4.0, Asus P5GD2-Deluxe Mobo, Pentium 4 2.8GHz, 2 x 1GB RAM, NVidia GeForce 6600... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Wed, Oct 28 2009 2:25 PM In reply to
    • sverkalo
    • Thessaloniki Greece
    • Posts 4,789
    • Points 57,020
    I use this sometimes. ProDAD's Vitascene has many excellent such effects.
    Vitascene.
    Desktop
    Armor 8000/Zalman 600W/Abit IP35Pro/Quad 6600@3G/8G Corsair DDR2 800/Geforce 8800GTS 640@Quadro FX 5600(169.47)/X-Fi Xtreme Music/160WD S2/2x1TB Samsung F1(RAID 0)/Many e-SATA drives/Samsung 203B/Vista Business SP1 64bit/Avid Media Composer 3.1.3 Suite/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    Laptop
    Fujitsu Siemens(Amilo Xi 2528-07)/T8100/3G DDR2/8600M GS 256/Realtek HD/Many e-SATA drives/Optiarc 7540/Optiarc 7240S(USB)/Vista Business SP1 32bit/Avid Media Composer 3.1.3 Suite.
    My Films
  • Wed, Oct 28 2009 2:26 PM In reply to
    • AKA Dave
    • Joined on Mon, Dec 3 2007
    • Posts 41
    • Points 490
    The Saphire 3 effects package also has a "DissolveGlow" transition that you can just drop onto the cut.  It's a nice one if you have the plugin.  If not as stated, the BCC Glow effect can be ramped up with dissolves or keyframed from within the effect itself.  You just have to add it to the next video layer above your transition point with add edits and then apply it to the clip of filler.
    Dave
    Dell M6400, Windows 7 Pro-64bit, 2.66MHz T9550, NVIDIA Quadro FX 2700M, 4gig RAM, Mojo SDI, External RAID and internal 2nd HD - Nitris DX on HP 8600. [view my complete system specs]
  • Mon, Nov 2 2009 4:39 PM In reply to
    • btwien
    • Mali, West-Afrika
    • Posts 79
    • Points 1,230
    Thanks guys for all the answers posted: I will definitely give it a try...
    What about giving the shot as a whole : a soft, "dreamy" feel ...?
  • Mon, Nov 2 2009 4:45 PM In reply to
    • camoscato
    • Posts 6,093
    • Points 73,065
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Try the BCC Film Process with the Highlight Blooming preset.  See if that says soft & dreamy to you.  :)
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Mon, Nov 2 2009 5:22 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 3,123
    • Points 35,675
    sverkalo:
    Vitascene.
    I still have the 90 days trials on my website in case someone wants to have more tools in the box to play with
    MC 4,03 ( Liquid 7,2 ) V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 8 GB, PNY Quadro 1800, Soundblaster X-Fi... [view my complete system specs]
    Tomas
  • Mon, Nov 2 2009 5:27 PM In reply to
    For "glow" transitions, I like to put a Color Effect over the transition point on Filler.  Then keyframe the White parameter under Luma Range down to about 32 @ the mid-point (where the cut occurs).  This causes the White to blowout at the cut.  Sometimes, I will also add a standard dissolve between the two clips.  So, if my Color Effect is 10 frames, at 5 frames in the White blows out and the dissolve I use under it would be 8 frames centered.
    I often find that many of the places I work don't have Sapphire installed, or they don't even have BCC installed (even though it comes free with MC).  So, I've relegated myself to using Avid standard effects most times - the best reason for using the Avid standard effects is that they are Real-Time.
  • Wed, Nov 4 2009 2:26 PM In reply to
    • btwien
    • Mali, West-Afrika
    • Posts 79
    • Points 1,230
    @ Kenton.VanNatten
    Thanks for the (hand made) answer... I will definitely give it a try!!
    Me myself do not have both BCC and Sapphire installed...As you mention BCC is free to install, you might want to give me some directions as to where to get it??
    Is this to be found under the download center of my avid (personal) page? Thanks!
  • Wed, Nov 4 2009 2:42 PM In reply to
    • btwien
    • Mali, West-Afrika
    • Posts 79
    • Points 1,230
    One more thing: you mention...
    I like to put a Color Effect OVER the transition point on Filler
    Explain the bold aspects a little more if you want, normally the Color Effect is "placed"  in one shot, not OVER the transition right?
  • Wed, Nov 4 2009 2:53 PM In reply to
    • camoscato
    • Posts 6,093
    • Points 73,065
      Moderator: Meridien
    btwien:
    Sorry, I just noticed you're running the Academic version, which does not include BCC.  If you want it, you'll have to purchase it.
    So follow Kenton's suggestions about doing it from within Media Composer instead.
    btwien:
    Step 1. Press CTRL+y to add a video track.
    You should now have a track named V2 above V1.
    Step 2. Activate V2 only.  Turn off all other video and audio tracks.
    Step 3. Put the blue position indicator on the edit point where you're going to make a transition.
    Step 4. Press Go Back 10 Frames (1 key on the top row).
    Step 5. Press Add Edit (h key.  May be different on some systems.)
    Step 6. Press Go Forward 10 Frames twice (2 key on the top row).
    Step 7. Press Add Edit
    Step 8. Drag and drop Color Correction effect onto 20 frame filler clip you created in steps 5 - 7.
    Now you have a Color Correction effect on a filler track (V2) over the transition point on V1.
    good luck,
    Carl
  • Wed, Nov 4 2009 7:37 PM In reply to
    btwien:
    Not necessarily.
    Nearly all of the effects (with the exception of some transitions) can be applied to a Filler track above all of the clips.  Let's say you have a group of 5 or 6 shots that you want to apply the same effect to.  You don't have to apply the same effect 5 or 6 times to each clip.  Just apply the effect once above the 5 or 6 shots on an empty Filler track.  So, for my Color Effect glow, I go to the cut point and back up about 5 frames, make an Add Edit onto the Filler then advance 10 frames and make another Add Edit on the Filler.  Then I drop the Color Effect on the section I've just isolated that sits over the clips and the cut point between them.
  • Fri, Nov 13 2009 3:00 PM In reply to
    • btwien
    • Mali, West-Afrika
    • Posts 79
    • Points 1,230
    @Kenton
    Got you, thanks! It worked, now I need to play around with it a bit.
  • Mon, Nov 16 2009 9:47 PM In reply to
    • iedjie
    • Posts 142
    • Points 1,640
    To get the BCC, (or any other plugin's), "glow-look" you can copy the video which is on v1 to v2. (For example with alt-C, than you load the selected videotrack from in to out point in the source monitor so you can place it unto another track or place in the timeline.)
    Than add a 3dwarp, than nest a colour effect and finally nest a blur. Scale the 3dwarp to 101 or 103 or so, add white to the colour effect and add some saturation, blur the whole image a little and after this play with the 3dwarp foreground slider to mix v2 with layer v1 and you will get the "glow-look".
    This nest on v2 can be alt-copied to the source monitor and applied to other places in the timeline. Offcourse you have to open the nest fully and replace the video with the video which is currently at v1. You can save the whole nest to a bin as a sub-sequence
  • Wed, Nov 25 2009 2:50 PM In reply to
    • btwien
    • Mali, West-Afrika
    • Posts 79
    • Points 1,230
    @ camoscato
    I now have the BCC effects loaded in my Media Composer and am wondering about the "soft & dreamy" you mentioned via BCC Film Process with the Highlight Blooming preset.
    I do see the BCC Film Process effect, but what about the 2nd part? Do I need to set these within the same effect or somewhere different?
