Latest post Tue, Oct 27 2009 9:10 PM by cjeffers. 3 replies.
  • Tue, Oct 27 2009 5:45 PM
    • cjeffers
    • Joined on Tue, Dec 16 2008
    • Wheaton, IL
    • Posts 12
    • Points 160
    MC 4.0, Vista 64 bit, & other tings!!!
    Hello,
    I'm really struggling with a matter. I've just installed MC 4.0.2 on my xw8600 Workstation (4GB ram), added Unity 5.1.3 Client (4.1.6 Server version), QT 7.6.2, & made sure that the nVidia FX 3700 graphics card has the proper driver, 182.65.
    PROBLEMs: At startup: Unity connection literally takes 5 minutes to connect.
    #2 MC 4 takes 30 seconds to 1 minute to load and the response time after that is poor
    #3 MC error msg: "Full screen playback is not supported on this system. For a list of supported graphics cards, please see www.avid.com/support"
    What do I have to do to correct this mess (outside of going back to XP)?
    HP xw8600, 4 Gigs RAM, MC 3.0.5, Mojo unit, nVidia Quadro FX 3700, 169.47 driver, Dual monitor setup. [view my complete system specs]
    Filed under: ,
  • Tue, Oct 27 2009 6:31 PM In reply to
    • cjeffers
    • Wheaton, IL
    • Posts 12
    • Points 160
    Re: MC 4.0, Vista 64 bit, & other tings!!!
    Hello again,
    I have just discovered the answers to my problems 1 & 2 thru the AVID knowledgebase (Surprise!)
    I need an Intel Pro 1000 PT copper card. The Systemboard NIC connections are not approved thru AVID. This is obviously slowing down my Unity connection and the application itself.
    On to issue #3 please....................
  • Tue, Oct 27 2009 6:39 PM In reply to
    Is Vista 64 compatible or approved for Unity 4.1.6?
    I thought XP SP 2 was the last approved OS for that version and anything higher would require either 4.2.3 or 5.
    FSP Should be supported with that config. Was the OS installation a clean install a upgrade from a previous installation?
    MC 3.1.3, Intel i7 920, Vista 64 bit, Nvidia GTX 275, 6 GB of RAM, X-Fi Titanium Professional, MSI X58 SLI Platinum. [view my complete system specs]
  • Tue, Oct 27 2009 9:10 PM In reply to
    • cjeffers
    • Wheaton, IL
    • Posts 12
    • Points 160
    Yes as long as you load Unity Client version 5.1.3 on your workstation.
    Again, I have verified that the first two questions of this post are solved.
    Now the third question has been resolved as well. The answer to that question was to load the 64 bit driver.
    Thanks, All issues solved!!!
