Latest post Tue, Oct 27 2009 6:00 PM by ian browns. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Oct 27 2009 12:06 PM
    • ian browns
    • Joined on Tue, Oct 27 2009
    • Posts 3
    • Points 35
    grouping clips with different timecode and the sound on an external card
    hello everyone.
    i just started working on a project shot in xdcam. its a documentry and for some of the shots they used two cameras. the sound was recorded on an external card. they had problems with the timecode generator so all the clips have different timecode.
    i imported the clips using the AMA and downconverted to 15:1 sd.
    first thing i did was to open a seq and sync all  the sound (which also had a different timecode..) now i have few seq's that are well synced. what is the best way to make the groups (i can load the other camera on Video 2 and make subclips but then its a seq which is not so good.) anybody knows?
    thanks alot and hope someone can help.
    cheers
  • Tue, Oct 27 2009 1:13 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 1,668
    • Points 21,295
    Re: grouping clips with different timecode and the sound on an external card
    Normally you use autosync to create you clips with audio and video married. This creates subclips. Then you would take those subclips and group them into a multigroup.
    As far as I know there is no way of grouping grouped clips.
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Tue, Oct 27 2009 2:06 PM In reply to
    • ian browns
    • Posts 3
    • Points 35
    thanks for your quick respond.
    the clips that r on the timeline r not grouped yet they r just synced to the sound (i didnt use the autosync) i need 2 know is there a way to make a groups from the timeline (i know how 2 do it from a bin) i think a mach frame is needed, but i dont know the worflow.
    thanks again.
  • Tue, Oct 27 2009 2:45 PM In reply to
    • outpostbc
    • Joined on Tue, Feb 21 2006
    • Lenexa,KS
    • Posts 279
    • Points 3,425
    Only master clips and subclips can be grouped. What you may need to do is  export a QT ref of your sequences, reimport so you have clips instead of sequences.
    Media Composer Nitris DX 4.0.2 Dual 3GHz Mac Pro 4GB Ram 10.5.7, Symphony Nitris DX 4.0.2 Dual 3GHz Mac Pro 4GB Ram 10.5.7, Unity MediaNet 5.1.3 [view my complete system specs]
  • Tue, Oct 27 2009 4:57 PM In reply to
    • helidon
    • Joined on Thu, Oct 8 2009
    • Posts 10
    • Points 90
    try to hilight the seq with the correct syncs and press the autosync button. this will create a sublip of the seq, just like it was a masterclip.
    duplicate the "master" seq first!
  • Tue, Oct 27 2009 6:00 PM In reply to
    • ian browns
    • Posts 3
    • Points 35
    thank u everyone for your help.
    i will try it and see what happens.
