Latest post Thu, Oct 29 2009 11:39 AM by chma. 2 replies.
  • Tue, Oct 27 2009 11:35 AM
    • chma
    • Joined on Thu, Nov 22 2007
    • Posts 27
    • Points 355
    DISK_INVALID_FILENAME_SYNTAX
    Currently using AMA during logging of about 20 hours of footage, divided on about 50 P2 card folders on a Raid5 setup. Very often i get the error: "Exception: DISK_INVALID_FILENAME_SYNTAX, filename:E:\Avid Projects\DeFredlose720p50\DeFredlv?se.wrt". Anyone got a clue what this could mean? I've looke through all the folders to make sure i don't have any characters that won't work with Avid, but i still get this error.
    Also often when adding a new AMA folder the clips start to populate, but the folder never shows up in Avid, the superbin names if self: "DeFredlv?se".
    Running MC 4.0.2, HP XW8200 Avid certified with Mojo SDI. No files imported to a Avid Mediafiles folder yet.
    EDIT:
    I also get this message a lot when this "DeFredlv?se" superbin tries to populate
    "________ Exception Report ________________________
    Exception Code: C0000005 ACCESS_VIOLATION
    Fault Module:   01:00248F6F C:\Program Files\Avid\Avid Media Composer\AvidMediaComposer.exe
    Fault Address:  00649F6F AApplicationBase::operator=+241BCF
    ________ Stack Dump _________________________________________
    00649F6F  0012E4D8  AApplicationBase::operator=+241BCF
    00629B84  0012E54C  AApplicationBase::operator=+2217E4
    05FFD4DB  0012E5F4  APaneBook::ShowPage+37B
    006338A0  0012E6CC  AApplicationBase::operator=+22B500
    0063343E  0012F1EC  AApplicationBase::operator=+22B09E
    008906CD  1B5A8224  AApplicationBase::operator=+48832D
    00CCDD5C  00CCDDA4  Symbol Not Found - Error 000001E7(00000487)
    00B3F604  00887AD0  AApplicationBase::operator=+737264
    E8502046  8BF18B56  Symbol Not Found - Error 0000007E(00000126)
    AVID SYSTEM DUMP - Tue Oct 27 13:09:19 2009
    ________ Memory ________________________________________________________
    numPtrs:      211783
    numHdls:      10769
    totalPtr:     0x021f0e3c (35589692)
    totalHdl:     0x0013d2a9 (1299113)
    ________ Current Program Stack _________________________________________
    7C90EB94  0012D5B8  KiFastSystemCallRet+0
    7C802532  0012D5CC  WaitForSingleObject+12
    60399852  0012D5E0  PSPrintStack+82
    6031471B  0012D670  DmpDump+9B
    60314C4B  0012D928  DmpDumpToFile+3CB
    60319EA0  0012DEE0  AvRgn::InternalHRGN+EF0
    6031AFA8  0012DF48  AvRgn::InternalHRGN+1FF8
    7C359C97  0012DF90  _CxxLongjmpUnwind+EA
    7C359629  0012DFC0  _CxxExceptionFilter+1C4
    7C3598AD  0012E018  _CxxExceptionFilter+448
    7C35994A  0012E048  _CxxExceptionFilter+4E5
    7C359B9D  0012E080  _CxxFrameHandler+26
    7C9037BF  0012E0A4  RtlConvertUlongToLargeInteger+7A
    7C90378B  0012E154  RtlConvertUlongToLargeInteger+46
    7C90EAFA  0012E4D8  KiUserExceptionDispatcher+E
    ________ System Configuration __________________________________________
    System software: Windows NT Version 5.1 Build 2600 Service Pack 2
    Processor type: Unknown Platform
    Physical Memory: 3327 MBytes; Virtual Memory: 2699 MBytes
    User name: Administrator
    Application info: Hitchcock_4.0.2_Patches_R30
    ________ Processes Currently Running ___________________________________
    ________ WindowList ____________________________________________________
    ________ Binary Modules Loaded _________________________________________
    ________ Device Drivers Loaded _________________________________________
  • Wed, Oct 28 2009 7:12 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 970
    • Points 11,915
      Moderator: Avid Symphony Nitris
    Re: DISK_INVALID_FILENAME_SYNTAX
    A .wrt file is the copy of the bin stored in RAM when a bin is saved.
    What is the actual name of the bin? Is this the same name of the P2 folder? Does it have a non-standard character like a /? Try renaming the bin and the P2 folder. Create a new bin and copy the clips from the old bin to the new bin.
    Rename and/or move and delete the Attic folder. There could be an issue with the copy of the bin in the attic.
    -- Bob Russo Applications Specialist at Avid Technology
  • Thu, Oct 29 2009 11:39 AM In reply to
    • chma
    • Posts 27
    • Points 355
    The case is that there's no bin called DeFredlv?se.wrt. I suspect someone at an earlier stage in this project had a bin called "defredløse" and the v? being how Avid interprets a Norwegian character. But at the moment there's no bins that have non standard characters in their bin names.
    I noticed though that when i use "Link to ama" sometimes the files show up in a Superbin called "DeFredlv?se", but there's no visible bin with that name on it.
    Some P2 ama folders see clips go offline and then they display "Virtual (H:\DeFredlose\RÅMATERIALE\09.02.12\Hardald's gym2)" as drive. The right drive would be "AMA (E:\DeFredlose\RAAMATERIALE\09.02.12\Hardald's gym2)", when i choose to Link to AMA everything works fine until I restart Avid, then all the clips show up offline and with the Virtual H as drive. At the moment manual relink at each start is the only option, no time to import and log all the clips over again.
    At the moment of about 30 hours footage in about 10 bins, some times only a few clips, seem to have trouble finding the P2 ama folder. What's even more strange is if there's one clip offline the MXF file for that clip are present in the right P2 folder, seems like the AMA function manage to ignore certain clips.
    EDIT:
    Also the first Syntax error prevents MC from being closed the proper way, have to use task manager and force it to close.
