Latest post Mon, Oct 26 2009 2:49 PM by Scott Carnegie. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Oct 26 2009 9:23 AM
    • btwien
    • Joined on Thu, Jan 15 2009
    • Mali, West-Afrika
    • Posts 74
    • Points 1,165
    Add filler at start
    Hello all,
    I do know the option "add filler at start" to add some black secs to the beginning of your video.
    Now, I do want to add some black before a (different) scene and thought: I use the same option,
    but with a selected shot....It will still at the filler totally at the start of the video though.
    How can I easily add some black secs at a certain position in my video?
    Thanks for your input!
    MC 4.0.2 Academic Version QT 7.6.2 Working with: PC, Windows XP Professional 2002, SP 3 AMD Phenom (tm) 9750 QuadCore Processor 2.41 GHz, 2.75 GB of... [view my complete system specs]
  • Mon, Oct 26 2009 9:38 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,036
    • Points 26,010
    • Moderator: MCA PC
    Re: Add filler at start
    One of my older tutorials.
    Many mistakes.
    But maybe it will help you.
    It starts with "adding black at start" then goes on to adding Fillers anywhere.
    Regards,
    Douglas
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Mon, Oct 26 2009 10:22 AM In reply to
    • sjpro
    • Posts 39
    • Points 520
    The reason you get 31 frames when you type in +30 is because Avid like most non-linear edit systems are based on film and the fact that every frame counts.  When you type +30, you are telling Avid +30 frames in addition to the frame that the position indicator is parked on.
    Steve
  • Mon, Oct 26 2009 10:36 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,036
    • Points 26,010
    • Moderator: MCA PC
    Thank you for adding the explanation, Steve.
    As I said it was one of my older Tutorials before I knew about the reason for the extra frame.
    In fact I made a newer Tutorial a few weeks ago explaining the phenomenon.
    Regards,
    Douglas
  • Mon, Oct 26 2009 12:54 PM In reply to
    • btwien
    • Mali, West-Afrika
    • Posts 74
    • Points 1,165
    Thanks for this tutorial Douglas, it helped me out!
  • Mon, Oct 26 2009 2:44 PM In reply to
    • Atomike
    • Nebraska
    • Posts 151
    • Points 2,385
    I LOVE the add filler at start command - in fact I have it mapped to a button on top my timeline. This tutorial got me wondering if there is any way to map an "add filler anywhere" button. The method described here is good, but not nearly as easy as a single button. I don't suppose there is any way to do this? I would love to set a default time of 10 seconds, and map that somewhere.
    Being able to put the cursor somewhere and immediately add 10 seconds of filler at the push of a button would be an immediate help to me, and I would image, most of the AVID using community.
    Media Composer 2.8 with Mojo. Quicktime 7.3 2 Xeon 3.4 Ghz 800 FSB Processors. Quadro FX 1500 256 MB PCIe Video Card. 2 Gigs Registered ECC Memory. Xeon... [view my complete system specs]
  • Mon, Oct 26 2009 2:49 PM In reply to
    I use "add filler at start" in every sequence I have to make room for slates. If you use it a lot you can map it or remember this -  alt > c > f
    :: Work - Symphony Nitris DX 3.5.1, HP xw8600 :: Home - Media Composer 4.0, Asus P5GD2-Deluxe Mobo, Pentium 4 2.8GHz, 2 x 1GB RAM, NVidia GeForce 6600... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
