Latest post Mon, Oct 26 2009 1:04 AM by Kenton.VanNatten. 8 replies.
Page 1 of 1 (9 items)
  • Sat, Oct 24 2009 9:35 PM
    • dew
    • Joined on Tue, Feb 27 2007
    • Posts 98
    • Points 1,250
    removing a person walking through shot
    Hi I have 26 frames were someone walks through a shot recorded outside. I thought this would be a good time to learn something new. So I read the tutorial on using BCC motion key to remove an object. It worked ok but you can see changes in the background were the person use to be at. It also is affecting the two people who needs to be seen in the shot. So I thought I would export a still before the person comes in at and reimport just the background to cover up the person. Is there any advice I can get on ways to remove this person. The more tricks I learn the better.
    thanks
    dew
  • Sat, Oct 24 2009 9:43 PM In reply to
    • camoscato
    • Posts 6,081
    • Points 72,960
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: removing a person walking through shot
    Hi dew,
    Depending on how much movement there is in the shot, you might get some use out of the Paint effect's cloning capability.  You could use it to clone one part of the background over the part that the person walks through.
    If you post a screen shot of the scene, you'll get better ideas.
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Sat, Oct 24 2009 10:31 PM In reply to
    The BorisFX site used to have a Tutotial /Demo clip on how to do this with BCC tracking
    Thanks for the continued dongle support
  • Sat, Oct 24 2009 11:51 PM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 581
    • Points 6,925
    Dew,
    Depending on the shot I'd probably FreezeFrame a "clean" shot of the background and then either use an AniMatte or Wipe to reveal portions.
    Alternatively, this is a tutorial I did a LONG time ago which is another way of isolating something that you ccould use in a different way:
    http://library.creativecow.net/articles/saleh_ra-ey/difference_matte.php
    Also, the tutorial Andrew is referring to is here:
    http://www.borisfx.com/tutorials/motion_key.php
    Ra-ey
    HP 8600 Symphony Nitris DX v4.0.2 Sapphire v2.081 Boris Continuum Complete v5.0.4 AvidFX (Boris Red) v5.8 Heroglyth v2.6 Vitascene v1 Adrenaline... [view my complete system specs]
  • Sun, Oct 25 2009 1:46 AM In reply to
    • Sycophant
    • Auckland, New Zealand
    • Posts 1,143
    • Points 13,860
    • Moderator: MCA Mac
    If it's a lock off shot the easiest thign to do is often simply put a copy of the shot on the layer above (offset by 10 frames or so) then use the Animatte tool to mask the person out. Set mode to Key In, draw a mask around the person (can usually be quite rough) and animate it.
    There are literally dozens of ways to address the depending on the shot and how complex it is to remove the offending part. BCC motion key is pretty cool, but I've usually found it's easier to use a manual method to achieve the same result.
    HP XW8600s - Media Composer 3.5.4 - HP XW8400s - DS Nitris 10.1 [view my complete system specs]
    Dylan Reeve - Editor and Stuff
    My opinions are my own.
    Dylan's Templater - Basic Avid project templating tool.
    BatchFuze - MetaFuze batch transcoding tools.
  • Sun, Oct 25 2009 9:53 PM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 581
    • Points 6,925
    I agree with Dylan - Animatte should be all you need.
    There has been just released a tutorial by DigitalJuice on BCC's Motion Key however - good timing!
    http://www.digitaljuice.com/djtv/detail.asp?sid=379
    Ra-ey
  • Sun, Oct 25 2009 11:15 PM In reply to
    • NICKB
    • Posts 732
    • Points 9,870
    For very complex removal problems take a look at this solution and watch the demo video
    Mokey
    http://www.imagineersystems.com
  • Mon, Oct 26 2009 12:35 AM In reply to
    • dew
    • Posts 98
    • Points 1,250
    Thanks guys for all of your help. I will look into the animatte filter. I did use BCC but didn't get the best of results. It may have been me as this was my first time using it. I will let you all know how it came out. Thanks again
  • Mon, Oct 26 2009 1:04 AM In reply to
    I recently used Animatte to cut out a fly that was buzzing around in the shot during a talking head interview - if it wasn't 1080p/24 I probably would've never noticed... yay for HD!
    I took a section of footage where the fly was not in the shot and placed it on V1, I placed my interviewee with fly buzzing around on V2.  Then I cut out the interviewee on V2 with Animatte and keyed him over the new background.  If I get permission from the client to use the footage for demo purposes, I may try to create a "Here's how I did it" video (also pending my free time)
