Latest post Mon, Oct 26 2009 8:04 PM by mmullen. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Oct 23 2009 6:06 PM
    • ronn
    • San Diego
    • Posts 401
    • Points 4,910
    New error in 4.0.2
    While trying to digitize from generic DV source over 1394,
    "Pyromaniac::ArmVideoConfidence - send message failed"
    and then it bails, performance becomes unusably sluggish.
    Media Composer 4.0.2, ASUS P6T/i7-920/12GB, Dell Studio XPS, i7-920/6GB, Windows Vista Ultimate 64 bit, HPxw8200 w/3GB/MC3.1.2/XP, FX1700, FX1300, FX570... [view my complete system specs]
    Ronn Kilby
    The Studio at Kilby Pond
    Valley Center, California
    www.kilbypond.com
    Where work - is a pleasure.
  • Fri, Oct 23 2009 8:04 PM In reply to
    • mmullen
    • Joined on Thu, Nov 13 2008
    • Posts 328
    • Points 3,850
    Re: New error in 4.0.2
  • Fri, Oct 23 2009 8:11 PM In reply to
    • ronn
    • San Diego
    • Posts 401
    • Points 4,910
    Thanks Matthew.
    Ronn Kilby
    www.kilbypond.com
  • Fri, Oct 23 2009 8:15 PM In reply to
    • mmullen
    • Posts 328
    • Points 3,850
    No problem. Let us know if any of those suggestions work!
  • Fri, Oct 23 2009 8:42 PM In reply to
    • ronn
    • San Diego
    • Posts 401
    • Points 4,910
    Seems to do the trick. Glad we have the KB (and folks like you maintaining it :) Should have searched there.
    Ronn Kilby
    www.kilbypond.com
  • Fri, Oct 23 2009 9:28 PM In reply to
    mmullen:
    Very interesting.
    I have ALWAYS turned the Adrenaline on first let it go completely through its startup and then turned the CPU on. This was the advice originally from my long time Avid supplier. A couple of years back I noticed a post by one of the regular Avid employees (posted in DS forum I think) suggesting starting the CPU first.
    I asked him a direct question and he confirmed starting the CPU first for DS(?) was correct but I should always start the Adrenaline first for MCA.  As the Adrenaline first practice has always worked here I have not questioned this. Reading that KB should I??
    Thanks for the continued dongle support
  • Mon, Oct 26 2009 6:48 PM In reply to
    • mmullen
    • Posts 328
    • Points 3,850
    With the adrenaline being Firewire before or after booting the CPU should not be an issue.
  • Mon, Oct 26 2009 7:49 PM In reply to
    From memory the Avid person was suggesting something about better memory allocation to the Adrenaline if the Adrenaline was started first.
  • Mon, Oct 26 2009 8:04 PM In reply to
    • mmullen
    • Posts 328
    • Points 3,850
    Regardless of whether the adrenaline is attached before or after boot up it's going to use the full 400 MB/s of Bandwidth....That is as long as there are no other devices connected on the same PCI segment.
    So basically it really shouldn't matter one way or the other.
