Latest post Sun, Oct 25 2009 11:57 PM by JohnnyReboot. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Oct 23 2009 11:27 AM
    • ThomasDubiel
    • Joined on Wed, Jan 28 2009
    • Chicago, IL
    • Posts 75
    • Points 950
    1080p/23.976 downconvert to sd not supported?
    Hello all,
    I have a 1080p/23.976 project and i need to create dvd deliverables. When i try to modify the clip to SD 23.976, i get a message saying that this conversion is not supported. I am running 3.0. All i need is to make an SD DVD, and when i try to transcode the original 1080p timeline by doing send to sorenson squeeze, then transcoding to dvd 16X9 lg, i get an image that has severe color distortion, which i figured that there would be a problem. So basically, how do i create a high quality sd dvd from a 1080p timeline?! Thanks,
    Tom
    Avid MC v3.0, windows vists sp1, gigabyte ga-ex58-ud4p mobo,6GB 1800 Mhz ram, nvidia quadro fx 1800, 500 GB 7200 rpm boot drive, 1TB 7200 rpm media drive... [view my complete system specs]
  • Fri, Oct 23 2009 2:44 PM In reply to
    Re: 1080p/23.976 downconvert to sd not supported?
    In order to do SD outputs, you need not convert the clips or sequence, you simple change the project format (Format tab in the Project window) to a compatible SD resolution. From there, you can do SD outputs. After that, it's just like any SD DVD you make.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Fri, Oct 23 2009 7:05 PM In reply to
    • ThomasDubiel
    • Chicago, IL
    • Posts 75
    • Points 950
    Job,
    Thanks, i will do that, for some reason i thought i had to modify the sequence, then output. Thanks!
    Tom
  • Fri, Oct 23 2009 7:14 PM In reply to
    • sverkalo
    • Thessaloniki Greece
    • Posts 4,787
    • Points 57,000
    A process which is simply and brilliant.
    Desktop
    Armor 8000/Zalman 600W/Abit IP35Pro/Quad 6600@3G/8G Corsair DDR2 800/Geforce 8800GTS 640@Quadro FX 5600(169.47)/X-Fi Xtreme Music/160WD S2/2x1TB Samsung F1(RAID 0)/Many e-SATA drives/Samsung 203B/Vista Business SP1 64bit/Avid Media Composer 3.1.3 Suite/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    Laptop
    Fujitsu Siemens(Amilo Xi 2528-07)/T8100/3G DDR2/8600M GS 256/Realtek HD/Many e-SATA drives/Optiarc 7540/Optiarc 7240S(USB)/Vista Business SP1 32bit/Avid Media Composer 3.1.3 Suite.
    My Films
  • Fri, Oct 23 2009 8:39 PM In reply to
    • JohnnyReboot
    • Southern CA
    • Posts 709
    • Points 8,595
    Changing the format tab to 23.976p NTSC in Thomas' project is easy enough...can anyone tell me what one would do in a 720p/59.94 project where there is no tab to switch to a SD res?  Assuming I want to get to a SD DVD.
    Thanks, JR
    Media Composer v3.1.1-IE7-HP xw8000-TYAN Mobo S2663-Dual 2.8 Xeons-Hyperthreading On-3G RAM-Executed Install3GB.bat-Page File Initial/Max set to 2048/4092MB... [view my complete system specs]
    That's right...an xw8000.
  • Fri, Oct 23 2009 9:27 PM In reply to
    • sverkalo
    • Posts 4,787
    • Points 57,000
    Output a qt ref for Avid DVD.
    Or a qt movie for ConvertXtoDvd which is excellent.
    Desktop
    Laptop
    My Films
  • Fri, Oct 23 2009 9:44 PM In reply to
    • JohnnyReboot
    • Southern CA
    • Posts 709
    • Points 8,595
    sverkalo:
    Thanks!
    Is there a particular reason why there can be no tab to switch to SD in a 720p/59.94 project?  I go out from the timeline to a standalone DVD recorder via firewire.
  • Sat, Oct 24 2009 4:40 AM In reply to
    • doxilia
    • Montreal, Canada
    • Posts 324
    • Points 3,830
    Ah,
    its been a while since I've been on the Avid forum! Good to be back.
    Yes, there is a good reason why different project formats don't allow you to switch to a different resolution and frame rate. Only compatible switches are allowed. In other words, for a 1080p/23.98 project, the equivalent SD format is 486p/23.98. The only difference here is the frame resolution while the frame rate remains constant.
    For a 720p/59.94 (Varicam, HDX) Panasonic project, there is no compatible 486p/59.94 format. In fact, SD only technically exists as 25i and 30i as far as I/O is concerned (as noted in the Avid project table when one starts a project). 24p on SD NTSC is permissible by the advent of pulldown but actually the tape is really a 30i tape. Of course, the tape can be re-interpreted to obtain back the 24p if desired when digitized.
    There is no standard for applying pulldown for 60p footage on to NTSC.
    Hope that helps, David.
  • Sat, Oct 24 2009 7:22 AM In reply to
    JohnnyReboot:
    The framerate difference would not allow proper metadata tracking. The solution is to use V4, open an SD project and open your 720p/59.94 sequence. It will create a duplicate of the sequence, automatically speed corrected/converted.
  • Sun, Oct 25 2009 8:01 PM In reply to
    • JohnnyReboot
    • Southern CA
    • Posts 709
    • Points 8,595
    Job ter Burg:
    JohnnyReboot:
    Job, what is the new, magic feature in MC v4.x that enables this solution?  AMA?  I read through the v4.02 ReadMe but...
    Thx guys, JR
  • Sun, Oct 25 2009 8:10 PM In reply to
    • Codec Moment
    • Joined on Mon, May 21 2007
    • Philadelphia
    • Posts 314
    • Points 3,985
    v4 allows mixed frame rates.
    Mac OSX 10.5.6 Avid Media Composer v4.0 soft Macbook Pro 2.5GHz Intel Core 2 Duo 2 GB 667 MHz DDR2 SDRAM Galaxy Metal Gear Box with 2 WD Caviar... [view my complete system specs]
    I trust orange juice more than I trust most people.
  • Sun, Oct 25 2009 11:57 PM In reply to
    • JohnnyReboot
    • Southern CA
    • Posts 709
    • Points 8,595
    Codec Moment:
    Oh yeah, that...my duh. Stick out tongue
    Thx!
