Latest post Fri, Oct 23 2009 11:11 PM by dc7100. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Oct 22 2009 10:38 PM
    • dc7100
    • Joined on Thu, Oct 22 2009
    • Posts 4
    • Points 40
    droped frames while in digital cut due to sub titles
    hi every body
    iam experiencing a terrible problem with subtitles : iam working on a film subtitling 1h30min, i finished everything and when in digital cut the application stopes due to frames drop, iam working with 2:1 res for each track, i tried to render subtitles which are on the 3rd video track but no way, i tried video mixdown also but it starts to render "mixdown" and stopes with an error that say that there no suficient memory.
    idont know what is hapening i have MC ADRENALINE 2.6.4- HP XW 8200  3.4GHZ 2 GB ram scsi drives, so please help me and i have to respect the deadline
    thank yo a lot.
  • Fri, Oct 23 2009 8:23 AM In reply to
    • camoscato
    • Posts 6,076
    • Points 72,920
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: droped frames while in digital cut due to sub titles
    dc7100:
    What happens when you try to render the subtitles?
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Fri, Oct 23 2009 9:28 AM In reply to
    • Neil J
    • Posts 208
    • Points 2,595
    Do you have complex audio? Try deselecting the audio and play out video on its own. Then do a seperate audio only play out.
    Pain but something i found works on a similar system with complex audio & video.
  • Fri, Oct 23 2009 11:58 AM In reply to
    • dc7100
    • Posts 4
    • Points 40
    hi
    the application renders effects and subtitles with no problems but there is no real time playback in digital cut due to dropped fremes.
  • Fri, Oct 23 2009 12:05 PM In reply to
    • dc7100
    • Posts 4
    • Points 40
    Neil J:
    hi
    i dont have complex audio, i have 4 tracks 2 coming from protools "stereo mixed  audio" and 2 tracks for the "generique" titles in the end.
  • Fri, Oct 23 2009 11:01 PM In reply to
    • Neil J
    • Posts 208
    • Points 2,595
    Did you try Digital Cut without the audio?
  • Fri, Oct 23 2009 11:11 PM In reply to
    • dc7100
    • Posts 4
    • Points 40
    Neil J:
    hi
    yes i tried it but the result is the same, play back is also drpping frames
