Latest post Thu, Oct 29 2009 6:01 AM by dingo1. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Oct 22 2009 7:08 PM
    Importing a Quicktime into the Nitris
    We're trying to go green and accept commercials in a QuickTime format instead of using dub tapes.
    My problem is when I import QT movies into my Symphony Nitris, sometimes the spot gets "streaks" through the video on fast-moving scenes and graphics.
    I've tried importing the movie in all three different File Field Orders (Non-interlaced/Odd/Even) but to no avail.
    Is there ANY WAY I can import these QuickTime Movies and have them not "streak" upon playback?
    HELP!
    Part time Player
  • Thu, Oct 22 2009 9:28 PM In reply to
    • outpostbc
    • Joined on Tue, Feb 21 2006
    • Lenexa,KS
    • Posts 279
    • Points 3,425
    Re: Importing a Quicktime into the Nitris
    Are these QT files 720x486 or 720x480? I have had issues like this when I import 720x480 at a 720x486 resolution. This is due to the 6 line difference in the video formats. If they are indeed 720x480, you need to import at DV25.
    Media Composer Nitris DX 4.0.2 Dual 3GHz Mac Pro 4GB Ram 10.5.7, Symphony Nitris DX 4.0.2 Dual 3GHz Mac Pro 4GB Ram 10.5.7, Unity MediaNet 5.1.3 [view my complete system specs]
  • Fri, Oct 23 2009 8:25 AM In reply to
    • camoscato
    • Posts 6,077
    • Points 72,925
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    In addition to outpostbc's questions, are you seeing the streaking on the computer monitor or the video monitor or both?
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Fri, Oct 23 2009 9:06 AM In reply to
    • Neil J
    • Posts 208
    • Points 2,595
    And what codec is the supplied QT?
  • Fri, Oct 23 2009 2:25 PM In reply to
    These files are supposed to be 720 x 486.
    And yes...the streaking occurs on both TV and computer monitors.
    The Compression Type is H.264.
    Does any of this help?
    There is a point where it asks if I want to import using the resolution of the clip or the resolution set up in the Avid.
    Also...does it make a difference if I'm importing a file onto the E drive instead of a media drive like drives M or N?
  • Fri, Oct 23 2009 10:59 PM In reply to
    • Neil J
    • Posts 208
    • Points 2,595
    Compression is your problem, so, no - nothing to do with where the media resides.
    H264 is not an uncompressed format. And frame size is no reflection of quality.
    Back to the QT provider - this has nothing to do with being "green".
  • Thu, Oct 29 2009 6:01 AM In reply to
    • dingo1
    • Grinnell
    • Posts 194
    • Points 2,380
    Yes we are having to accept a wide variety of files from way too wide a range of folks....as to the streaking...maybe h264 artifacts and maybe not...try this just for fun...open the QT in quicktime pro and export as a qt avid meridian compressed codec.....some how when I get weird files if I resave them as a different codec within quicktime and import to avid I get a better result...makes no sense but it works (sometimes) luck
    GGGGGG
    2 PC NCA 8 on isis 1Mac MCA 2.8 on local scsi 1 Symphony Nitris classic 4.0 Passel full of PC express pros on Dells 1 express pro on macbook pro [view my complete system specs]
