Latest post Thu, Oct 22 2009 5:00 PM by mfantu. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Oct 22 2009 4:29 PM
    • mfantu
    • Joined on Fri, Jul 3 2009
    • Toronto
    • Posts 14
    • Points 190
    Export from AE = Stutter in MC 3.5
    Hey guys. I export to After effects from Avid like i usually do using a QT ref. After applying the effects i send it back to Avid with the standard "Lossless" setting. This is usually never an issue. *(Recently i installed Red Giants "Looks" and "Colorista".) Then i started work on a music video and used the same process. When i brought it back into Avid i had playback issues of that video. Everything else plays fine. But after a few moments just that particular video starts to stutter. The audio plays fine. Any ideas or is it most likely the plugins? I also tried exporting as DNxHD, but still the same deal.
    Thanks.
    Marcos
    MC 3.5 | Win XP Pro SP3 | Quadro FX 3500 | Core 2 Quad 2.4GHz | 3GB RAM [view my complete system specs]
  • Thu, Oct 22 2009 5:00 PM In reply to
    • mfantu
    • Toronto
    • Posts 14
    • Points 190
    Re: Export from AE = Stutter in MC 3.5
    WEll, just my luck guys, i had a hard drive issue about a month ago and now it appears to be another one. The drive i was exporting to from AE seems to be acting up. When i removed the file and brought it into another drive then imported it into Avid agaom it plays perfectly. Go figure.
    Thanks again.
