So i'm having an issue with the symphony Nitris (Lastest Version) Enabling the wrong audio channels on a SR deck on an Insert Edit. for Example Im tring to insert channels 11 and 12 and it will enable 7 and 8 and 11 and 12 on the deck so I am having to disable the tracks manually from the deck and it is getting pretty annoying. If anyone can help I would appreciate it, Thanks!!
Could be the SR deck is set to arm 7 & 11 when it gets the command to arm 7. SR manual should tell you how to check that.
Avid, FCP, EVS, Tape, whatever.
Online diary and showreel at webdiary.tv
Checked the Deck and it wasnt the issue, so I called up Avid and found out its a bug and should be resolved in the next version update. Thanks anyway.
