Latest post Sat, Oct 24 2009 5:23 PM by Scotious. 7 replies.
  • Tue, Oct 20 2009 5:32 PM
    • Scotious
    • Posts 8
    • Points 80
    "Export Audio Too Large"
    I have an HDV project imported native (1080i).  These are all day conferences and the sequences run 4-5 hrs. When I export to h.264 (960 x 540) I am getting the error/exception message above (export audio too large.)  Seems there is a length limit to the audio.  If I export video only, fine.  If I break up the exports into sections I have no problems outputting about  2-1/4 at a time.
    It's not a drive space issue.  I'm exporting with about 1TB available and the files end up to be approx. 1GB per hour.
    Any advice?
    I am on a dual G5, 2.0GB, OS 10.4.11, xpress pro 5.6.4.
    Thanks in advance--  Scott
  • Tue, Oct 20 2009 10:53 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,885
    • Points 32,930
    Re: "Export Audio Too Large"
    You're hitting a QT file size limit.  Keep the files to under 2 GB each.
  • Tue, Oct 20 2009 10:55 PM In reply to
    I've exported QT files that are way larger than 2GB.  I'm not so sure that's the issue.
  • Wed, Oct 21 2009 5:51 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,885
    • Points 32,930
    Depends on the QT version and the disk file type.  It had been a problem in the past.
  • Wed, Oct 21 2009 3:46 PM In reply to
    • Scotious
    • Posts 8
    • Points 80
    Maybe it is the h.264 type.  I certainly have exported other .mov's much much bigger than 2GB, so if anyone really has the scoop on this I would appreciate it.  FYI, my drives are usually formatted Mac OS extended (journaled.)  --Scott
  • Thu, Oct 22 2009 1:10 PM In reply to
    • Scotious
    • Posts 8
    • Points 80
    HBrock-- What do you mean by "disk file type?"  Hard drive or QT type? I'm running QT 7.6.4 on Xpress Pro 5.6.7 (mot 5.6.4 as I state above.)  OK-- maybe this QT version is not fully blessed by Avid, but certainly it has caused no other issues for me.
    Why only is the "Export Audio Too Large?"  The video takes up much more disk space.  Mods?  Avid folks?
  • Sat, Oct 24 2009 1:44 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,885
    • Points 32,930
    If your disk is formatted FAT32 rather than HFS+ you won't be able to write files larger than 2 GB.
  • Sat, Oct 24 2009 5:23 PM In reply to
    • Scotious
    • Posts 8
    • Points 80
    No no, I know about the 2GB file limit.  I'm formatted HFS+ -  Have exported QT files in the 10's & 20's & 30's of GB's.  the real bummer here is that I am on a PPC and the Elgato Turbo h.264 accelerator will not work  :-(((
    Oy Vell...
