Latest post Wed, Oct 21 2009 12:11 AM by Clement Canino. 3 replies.
  • Tue, Oct 20 2009 3:11 PM
    • JamesG
    • Posts 109
    • Points 1,460
    trouble capturing DV
    My Set-up:
    MC2.8.3
    Dell Precision 670
    Fx3400 video card
    Mojo on internal bus
    Pyro card fitted but no drives attached
    SCSI Raid Array on UL4D
    I can't seem to capture more than a couple of minutes through the Mojo without getting
    "Data loss has been detected on the 1394 bus and the capture has been interupted.The cause maybe due to other activity in the system or due to a bad tape thread You can skip over theses errors by deselecting "stop capture if a bad frame is detected " in the capture settings ." (this is already deselected)
    I tried plugging the DVcam deck into the Pyro card but couldn't get the capture tool to switch to OHCI without physically removing the Mojo.  Is that right or is there another way?
    Now capturing fine via Firewire into Pryo card with no problems, Mojo disconnected.
    Any idea what might be wrong??  Mojo is behaving otherwise fine...
    PC: MC 2.8.3, Dell Precision 670, Windows XP, Mojo on internal bus, Pyro card, SCSI Raid Array on UL4D. MAC : MC3.1.2 software only on MacBook Pro [view my complete system specs]
  • Tue, Oct 20 2009 6:30 PM In reply to
    • Posts 1,595
    • Points 19,895
      Avid Employee
      Moderator: Broadcast Newsroom
    Re: trouble capturing DV
    what slots are your cards in?
    http://www.avid.com/resources/qualified/Dell%20670.pdf
    Customer Advocate/Customer Success [view my complete system specs]
    813-493-6800 mobile
    AOL IM avidmarianna
  • Tue, Oct 20 2009 10:55 PM In reply to
    • JamesG
    • Posts 109
    • Points 1,460
    I'm sure all is in the proper place - I'v been cutting on this machine for years.
    Any other thoughts?
  • Wed, Oct 21 2009 12:11 AM In reply to
    I always thought Mojo should be attached to the Pyro card not the internal 1394. The deck should attach to the internal card, but you are right, you SHOULD be able to attach it to the Mojo too and select 1394 on the timeline.
    HP XW6400, 2x 3.0 dual Xeon 4g ram, Quadro FX 3500, XP Pro SP2 Pyro 64, MOJO, MOJO DX, latest nvidia drivers from Avid install disk, recommended QT version... [view my complete system specs]
