Latest post Tue, Oct 20 2009 2:59 PM by saleems786. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Oct 19 2009 5:21 PM
    • saleems786
    • Joined on Mon, Oct 19 2009
    • Posts 4
    • Points 40
    MC 3.0 not showing the IEEE-1394 Fireware input
    We have installed media composer  version 3.0 with  Avid mojo SDI , after installation i can not able to see the fireware port in caputer tool .
    except fireware input its showing  all composit , Svideo , component and SDI input.
    we have MC on HPXw 8600 on windows XP SP2- 32bit
    Please can you adivse the possible solution.
    thanks
  • Mon, Oct 19 2009 5:57 PM In reply to
    • maxvideo
    • Posts 47
    • Points 580
    Re: MC 3.0 not showing the IEEE-1394 Fireware input
    What is your configuration ?
    How you connect Mojo SDI to the CPU ?? Do you use onboard firewire port or another card ?
    I have tested XW8600 with Mojo SDI / and optional Firewire card, as Avid reccomended / and all work without any problem.
    MC MojoDX 3.5.1, WinXP SP3,QT 7,6, HP XW8600 workstation / 2xXeon Quad Core 3,0 GHz, NVidia Quadro 3700, 4Gb RAM / Atto UL-5D SCSI controller with external... [view my complete system specs]
  • Tue, Oct 20 2009 7:51 AM In reply to
    • saleems786
    • Posts 4
    • Points 40
    HP XW8600
    Xeon E5420 Quad 2.5Ghz
    RAM 2GB
    250GB HDD
    Fire wire Card: ADS Pyro P/N:7030-03117-01
    I can see in Capture tool Composit,Component,SVideo and SDI Exept Fire wire input
    Thannks
  • Tue, Oct 20 2009 7:53 AM In reply to
    • saleems786
    • Posts 4
    • Points 40
    HP XW8600
    RAM 2GB
    250GB HDD
    Graphics Card:Quadro FX1500
    Thannks
  • Tue, Oct 20 2009 8:03 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,412
    • Points 16,210
    You should see DNA 1394, try to add a deck configuration for a firewire channel either on the Avid DNA or OHCI.
    MC 3.5/Mojo, Vista 64 biz, Gigabyte GA-EP45T-EXTREME, Intel Q9450, 8 GB ram, Pyro 64, Quadro FX 1700, 2 x 1TB drives (raid 0) for mediafiles + G4 MacBook... [view my complete system specs]
    peace luca
  • Tue, Oct 20 2009 2:59 PM In reply to
    • saleems786
    • Posts 4
    • Points 40
    I add the deck but there is nothing happen,Installation seems good but it could not shows the DNA Firewire input in capture tool.
