Latest post Sat, Oct 17 2009 3:14 PM by Kenton.VanNatten. 5 replies.
Page 1 of 1 (6 items)
  • Sat, Oct 17 2009 4:11 AM
    • Strider
    • Joined on Fri, Sep 1 2006
    • Los Angeles
    • Posts 100
    • Points 1,485
    How to import super low res to work with without media chugging?
    Hello, I would like to know how to vastly down res footage on import so I can work with it seamlesly. Even when I importlow res small files they don't play properly and chug so I was wondering if there is a way I can do this?
    Strider
    Intel(R) Xeon(R) CPU 5130 @ 2.00GHz 2.00Ghz, 3.00GB of RAM [view my complete system specs]
    STRIDER
  • Sat, Oct 17 2009 4:18 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,838
    • Points 201,280
    Re: How to import super low res to work with without media chugging?
    Sure, just change the resolution on import. The lowest and easiest to play back is DV25.
  • Sat, Oct 17 2009 4:23 AM In reply to
    • Strider
    • Los Angeles
    • Posts 100
    • Points 1,485
    Ok great thanks very much. However for some reason the only ones I have to choose from under "video resolution" when I import are DNxHD 145 MXF, DNxHD 220 MXF, DNxHD 220X MXF, DVC Pro HD MXF, 1:1 MXF and 1:1 10b MXF.
    Is there another place I would be able to change this to DV25?
    Strider
    STRIDER
  • Sat, Oct 17 2009 4:42 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,838
    • Points 201,280
    In what project type? That sounds like HD. You won't get DV 25 in and HD project.
  • Sat, Oct 17 2009 5:26 AM In reply to
    Switch the project type to SD under the Format Tab in the Project Window.  You'll then have SD resolution options.  See "Changing the Project Format" in the built-in HELP.
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Sat, Oct 17 2009 3:14 PM In reply to
    Also, what type of system are you on?  What's your storage?
    If you're working in an HD project, it's not surprising to see some stuttering playback on certain storage or under-spec systems.
