Latest post Sun, Nov 1 2009 2:06 PM by TCurren. 7 replies.
  • Fri, Oct 16 2009 6:26 PM
    • kinozoom
    • Posts 32
    • Points 470
    Renders not sticking
    I just upgraded to 4.0.2 and now I'll render in to out and my fx wont play properly. When I look at the timeline it still has red lines over some fx so I'll render in to out again and it will try to render the same number of fx as before. In fact I can just keep hitting render and it will "render" them but if I hit render again immediately afterwards it still has to render the same number of shots.
    If I clear the renders then try again it seems to fix it for a while.
    Any one see this before?
  • Fri, Oct 16 2009 6:34 PM In reply to
    Re: Renders not sticking
    kinozoom:
    Saw it with one title over filler not rendering yesterday on MC 4.02 on Mac. Worked around it by doing a video mixdown so I could output.
    Thanks for the continued dongle support
  • Fri, Oct 16 2009 6:40 PM In reply to
    • outpostbc
    • Joined on Tue, Feb 21 2006
    • Lenexa,KS
    • Posts 280
    • Points 3,450
    I have the same issue occasionally. I have to do a mixdown to work around it. I have it happen with various effects Sapphire, Boris and Avid effects.
    Media Composer Nitris DX 4.0.2 Dual 3GHz Mac Pro 4GB Ram 10.5.7, Symphony Nitris DX 4.0.2 Dual 3GHz Mac Pro 4GB Ram 10.5.7, Unity MediaNet 5.1.3 [view my complete system specs]
  • Sat, Oct 17 2009 5:48 PM In reply to
    • TrevorA
    • Posts 159
    • Points 1,835
    I've known it happen when ISIS workspaces are modified (R/W from Read only) after mounting. Have to restart App for renders to stick in that case.
    Not sure that is the issue for your setup though.
    Avid, FCP, EVS, Tape, whatever.
    Online diary and showreel at webdiary.tv
  • Mon, Oct 19 2009 5:30 PM In reply to
    • mmullen
    • Joined on Thu, Nov 13 2008
    • Posts 327
    • Points 3,835
    Have you tried creating a new Avid user?
  • Mon, Oct 19 2009 5:35 PM In reply to
    • Neil J
    • Posts 208
    • Points 2,595
    Seen this occasionally too. There seems to be little logic as to why and when it happens. I have found quitting Symphony and going back into project works most times and any renders that didn't seem to have "stuck" were now there.
    Annoying but not really that frequent an occurence either..
  • Sun, Nov 1 2009 9:43 AM In reply to
    • John Moore
    • Joined on Fri, Feb 3 2006
    • Burbank, CA
    • Posts 144
    • Points 1,615
    I've seen this on occasion and closing the sequence bin and reopening it fixes it sometimes.  This has historically helped even going back to meridian days.
    Symphony Nitris 3.1.1 [view my complete system specs]
    John Moore Barking Trout Productions bigfish@pacbell.net
  • Sun, Nov 1 2009 2:06 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 1,669
    • Points 21,300
    Hit it for the first time on Friday and yes, the old close the bin and reopen it worked. This bug has popped up in the past and been fixed before. Hopefully that makes it easy for the engineers to fix.
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
