Latest post Fri, Oct 16 2009 3:29 PM by Kenton.VanNatten. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Oct 16 2009 3:10 PM
    • Field Hudnall
    • Port Clinton, Ohio
    • Posts 160
    • Points 2,310
    Undo "Clear monitor" mistake!!!!
    Ok...I am freaking out right now.  I had a timeline built and I went to click and drag my composer monitor down and instead of dragging my composer monitor down I noticed in a matter of 1/2 second I clicked a drop down menu and clicked "clear monitor". My composer monitor is blank as is my timeline.  I tried to "Control Z" to undo it with no luck. I tried reloading my sequence back...blank.  What did I do?!?!?!  How do I get it back?!?!?!  PLEASE HELP
    Hewlett Packard 4-core (2 dual core Processors) HP XW8400 Quad Core (4-core) Workstation 3.0GHZ Dual Core Processors 4GB RAM (C:) System Drive 141GB... [view my complete system specs]
  • Fri, Oct 16 2009 3:14 PM In reply to
    • Neil J
    • Posts 208
    • Points 2,595
    Re: Undo "Clear monitor" mistake!!!!
    Eh... in the bin you created it in...??
    Just a hunch.
    • Field Hudnall
    • Posts 160
    • Points 2,310
    Never mind!!! I just figured it out. It shows the sequence in the drop down and you just have to click it.  Man talk about a scare that gets the heart going. LOL
  • Fri, Oct 16 2009 3:16 PM In reply to
    • Field Hudnall
    • Posts 160
    • Points 2,310
    It actually was not in the original bin. I tried loading the original sequence and I was blank...thats what scared me.  I figured that you could not delete that easly.
  • Fri, Oct 16 2009 3:29 PM In reply to
    • Neil J
    • Posts 208
    • Points 2,595
    Well it had to be in a bin somewhere....
    Field Hudnall:
    You can't.  If you hit "Clear Monitor" it just clears the Sequence that is loaded in the Timeline from the Record Monitor and subsequently the Timeline.  It is not "deleted".
    To Delete a sequence, you need to highlight it in the Bin and hit "Delete", then a confirmation dialog box appears.
    To re-load a seq that has been cleared, you can just double-click the sequence in the Bin that it lives in, double-clicking a seq always loads it into the Record Monitor.
