Latest post Fri, Nov 13 2009 10:19 AM by oze. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Oct 16 2009 1:51 AM
    • oze
    • New Zealand
    • Posts 200
    • Points 2,335
    Metafuze / Red Question
    I'm about to start work on an ad campaign next week that will be shot on RED (2 day shoot). I have been testing Metafuze for a little while now and am feeling familiar and confident enough to use it on a real job.  In the past, my RED rushes have been done by a large post house and then supplied to me as DNxHD files.
    My question is really one of reassurance  . . . that the AAF file Avid generates for this project will be able to translate frame accurately to the original R3D files in the Baselight grading system and the Flame session?
    I see no reason why the files I generate using Metafuse should be any different from the ones generated on say . . . a BLT system. Is this correct?
    Many thanks
    Mac Pro 2.66Ghz , 17GB RAM, NVidia 8800GT/512MB, OS 10.5.6, MC 3.5, 750Gb Internal, Analog Mojo, 23 inch Cinema Display. Also 17" MBP Unibody 2.93Mhz... [view my complete system specs]
  • Fri, Oct 16 2009 6:48 AM In reply to
    Re: Metafuze / Red Question
    I'd recommend a quick test. Should work, but my only concern would be the tapename/filename isssue.
    The Red SDK uses names like "A001_C001_091016_" for today, whereas the filename reads "A001_C001_1016AB_". This is an SDK issue. You use the Camroll entry as the actual filename for conforming, but I'm not sure how that will travel into Baselight with an AAF.
    But I'm not sure how BLT/Baselight handle this in the first place.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Mon, Oct 19 2009 11:10 AM In reply to
    • oze
    • New Zealand
    • Posts 200
    • Points 2,335
    Thanks Job ter Burg, sent a quick test to the post-house today and it's all good. So I'll move forward on this job and give it a go.
    Cheers
  • Mon, Nov 2 2009 5:41 AM In reply to
    • oze
    • New Zealand
    • Posts 200
    • Points 2,335
    oze:
    Cheers
    Job ter Burg, the job went smoothly but I have some feedback from the post house. The colourist indicated that the reel or tape names on the files that were generated by Metafuze were slightly modified in the process from the originals. They said thay have seen this before but it can be fixed.
    For example . . .
    An original R3D has the file name: A001_C001_1003M9
    When this file is scanned into Metafuze it appears as A001_C001_091003
    Everytime I import the files they come in with this change and it flows through to the AAF and RED16 EDL
    Is there a button, toggle or setting that I am not using correctly?
    Many thanks
  • Mon, Nov 2 2009 6:17 AM In reply to
    • oze
    • New Zealand
    • Posts 200
    • Points 2,335
    OK . . . just found it.  The reel number data I'm looking for is stored under the camera roll info so it's a simple switch change in EDL manager. Nice trap for young players . . . won't forget that one in a hurry.
    Cheers
  • Mon, Nov 2 2009 7:55 AM In reply to
    Yes, it's mentioned in the MF manual, though. And I wrote it earlier ib this thread as well, mentioning it as being one of the caveats:
    Also, this is a problem of the Red SDK using different namings at different stages more than it is a MF problem, or so I have come to understand.
  • Mon, Nov 2 2009 5:29 PM In reply to
    This naming convention was adopted by RED last year to avoid creation of duplicate file names. The "proper" date portion of the .R3D file is still contained within the metadata so MetaFuze can read it and pass it onto Media Composer.
    Igor Ridanovic
    www.HDhead.com
  • Sat, Nov 7 2009 10:52 PM In reply to
    • MichaelP
    • Boston
    • Posts 1,751
    • Points 21,670
      Moderator: Film
      Moderator: MetaFuze
    The SDK has been updated to persist the unique file ID at the end of the file into the R3D header. The next version of MetaFuze will have that change to that all apps can now be consistent in Tape Name being the 16 character file name.
    Michael
    HP 8600 Symphony Nitris DX v4 || MBP 15" Media Composer v4 [view my complete system specs]
    ____________ Anything 24fps
  • Fri, Nov 13 2009 10:19 AM In reply to
    • oze
    • New Zealand
    • Posts 200
    • Points 2,335
    Thanks Michael, that sounds great.
    I have been testing Metafuze on Windows 7 and it seems to work just fine. Will official support be coming on the next version?
