Latest post Fri, Oct 16 2009 1:18 AM by hbrock. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Oct 15 2009 11:27 PM
    XP 5.8.4 crashes on consolidate/playback
    Hi all
    I have a client working on a feature-length project with a large amount of media and attached drives (11 Firewire drives connected to a PowerMac G4 on 10.4.11, using FW800 PCI expansion cards). The system is pretty overloaded in terms of RAM, CPU capability and I/O, but at the moment they don't have the ability to do any upgrades.
    One of their issues is frequent crashing of Xpress Pro, especially when consolidating media between drives or playing back a sequence. Their application is 5.8.4 and Quicktime version is 7.1.6. They also have a Mojo directly attached to the Firewire bus.
    There's nothing obvious in the Avid log that speaks to me; I enclose the last few crash items in case anyone has the time and inclination to look at them and might have any insight. In every case, the crash log begins
    Exception:  EXC_BAD_ACCESS (0x0001)
    Codes:      KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
    Would it be a sensible troubleshooting step to delete precomputes, perhaps?
    Grateful for any advice - Thanks!
    Matt
  • Fri, Oct 16 2009 1:18 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,885
    • Points 32,930
    Re: XP 5.8.4 crashes on consolidate/playback
    Less is more.  Sounds like there is too much of something that's gumming up the works.  Could be bad media.  Could be a bad firewire drive on the bus.  Could be too many media files in a folder.  Could be too many objects taking up memory.  See if you can minimize things for a test to see if the problem can be eliminated if there is less of everything.
